-   -   Can the rear hubs be rebuilt? (http://zr1.net/forum/showthread.php?t=17107)
voxdeidave 04-03-2012 08:13 PM
Hey guys.....just curious.
All I have seen in the whimpy catalogs are complete units that have been rebuilt. I have just flipped over 100,000 and am chasing down a rolling vibration coming from the back of the car. Tires are freshly balanced, and still have about 50 percent tread left. Thinking abour doing ujoints and bearings soon, but the prices for hubs really shocked me. Has anyone done it themselves, and if so where did you source your bearings?
Thanks!
Dave
XfireZ51 04-03-2012 09:03 PM
Re: Can the rear hubs be rebuilt?
Thanks!
Dave
NO. Grab the rear tire top and bottom and see if there is any slop. If so, replace hub bearing. Once u remove it you'll understand.
GOLDCYLON 04-03-2012 09:20 PM
Will be worth it the road difference with fresh ones is awesome.
VetteMed 04-03-2012 09:58 PM
And, it may not be necessary to spend the $300+ for the delco units. I've heard some good feedback on the Timken units for about half the cost.
Daniel_Mc 04-03-2012 10:42 PM
You can also use the F body hubs same thing but cheaper. Just run the bolts in from the other direction.
Daniel
XfireZ51 04-03-2012 10:50 PM
Daniel
Dan,
We're discussing the rear hubs, not the fronts. BTW, I just replaced a rear hub using a Timken set for $180.
VetteMed 04-03-2012 10:58 PM
Daniel
I thought that was only an option for the fronts?
Daniel_Mc 04-03-2012 11:14 PM
It is just the fronts I didn't read it good before I posted. :sign12:
Daniel
voxdeidave 04-03-2012 11:21 PM
Cool to hear there is an option to the delco jobs! I have done the 12 and 6 thing, and really dont have any play to speak of, which is why im thinking my vibration is a bad ujoint. But with my milage it would be the right thing to do everything while im in there. Who would be your favorite source for the timken set? Will I need to talk to my buddy with the 20 ton press?( Just did hubs on my tr6, and the left hub sat on the press with full power for nearly two days before it finally let go!) Thanks for the help!
GOLDCYLON 04-04-2012 11:37 AM
Concur Timken makes some fine bearings
