-   -   UPDATE: Engine is pulled and secondaries gone!! (http://zr1.net/forum/showthread.php?t=16615)
oricale 01-31-2012 08:38 PM
So as you know us here at WAZOO land pulled the heart out of my ride,...here is a few pics of before and now,...
http://i917.photobucket.com/albums/ad18/oricale/036.jpg
the WHOLE car looked like this!!!,..
http://i917.photobucket.com/albums/ad18/oricale/035.jpg
http://i917.photobucket.com/albums/ad18/oricale/001.jpg
NOW:
http://i917.photobucket.com/albums/a...cale/054-1.jpg
http://i917.photobucket.com/albums/a...cale/059-2.jpg
SO,..the heads are @ C&C machine in Manassas,...
And I thought since I have ripped the entire system, down to the last screw of the secondaries..I would offer them to the highest bidder !!!
http://i917.photobucket.com/albums/ad18/oricale/025.jpg
Anyway I am ordering a A$$ load of stuff from Haibeck and Jerrys as well as some other sources,...
Here's what were loading into the Z:
Headers
all new gaskets
Haibeck chip(when ready)for the secondary delete
Samco rubbers
new timing chains (primary and secondary)
all tensioners
Heads ported to 36mm
new exhaust
4:10's
ect(too much to list..
Anyway, I thought I would give a few Ideas on a few things:
Secondary butter flies and shafts removal:
uses the right torx bit, they will all come out with enough pressure( i used a electric drill. no problem,
The shafts I used a small flat head screwdriver and popped them out by layin the flat head against the inside of the shaft and used one medium hit with a hammer and they came right out!,...
I will be happy to lay out any information i can just let me know!...
VetteMed 02-01-2012 07:57 PM
Re: UPDATE: Engine is pulled and secondaries gone!!
Looks like fun! :)
ZZZZZR1 02-01-2012 08:41 PM
Only cow batman!!!!!!!
Now that's a project. :saluting:
:cheers:
Blue Flame Restorations 02-01-2012 09:04 PM
Always nice to see this type of thing. Keep the pics coming!!!!
LGAFF 02-01-2012 10:03 PM
Thats either a Black Widow wrinkle finish block or you had a massive amount of oil leaking.
tccrab 02-02-2012 12:50 AM
Judging by the "After" picture, it was just oil and road grime.
TomC
'Crabs
rhipsher 02-02-2012 01:03 AM
If I had to go that far with my motor I'd seriously consider a 368 build or better.
Corbusa 02-02-2012 02:02 AM
If I knew what they were worth or If I'd ever need them, I'd see what I could do..:)
It looks like you're having fun, wish I was there to help..
