ATI Dampner and front cover
Do I need to mod a 90 front cover for the ATI dampner?
Re: ATI Dampner and front cover
Lee,you have to grind down a couple of water pump screw bosses and take off the stock timing indicator. Check the ATI might be a bit too tight,measure the stock damper hole and the ATI hole. It'll go on but might ruin your installer tool. Pete |
Good to know Pete; Thanks! Those jokers at ATI should not even market this as an application for the LT5 with these issues to install and it what kept me away from it. I notice on their website they don't even have footnotes like other application and make it seem like you just bolt it on.
My machinist fixed the too tight issue, that how they are made....
