-   -   Trouble code list for 1990 (http://zr1.net/forum/showthread.php?t=12475)
Don in VT 07-27-2010 03:51 PM
Hi,
I am waiting for manuals. In the meantime I have an INFL REST light on and I want to scan for a code or whatever.
Does anyone have a list for the 90 trouble code numbers that they can email me ?
Thanks
Don
GOLDCYLON 07-27-2010 04:54 PM
Re: Trouble code list for 1990
Prob corrosion on the sensors. The MY 90 was famous for that
tccrab 07-27-2010 04:56 PM
Still looking for list of codes, but this could be useful....
http://www.zr1netregistry.com/Old_Proj/old_proj7.htm
TomC
"Crabs
GOLDCYLON 07-27-2010 05:05 PM
http://www.zr1.net/forum/showthread....ighlight=codes
Heres a few from Cliff Et AL
http://www.troublecodes.net/GM/90_57J.shtml
A1990 07-27-2010 05:09 PM
Once you fix this issue, the timing to reset the code is critical. When I had this code, took me several tries to reset the code.
Aurora40 07-27-2010 07:57 PM
FYI, to get the SIR codes, ground pin "K" of the ALDL (third pin from the right on the bottom row) and then turn the ignition to "run", but don't start the car. The INFL REST light will blink the codes.
Post up what you get, and I'll tell you what it means. There are like 20 different codes and I'd rather not type them all out.
jrd1990zr1 07-27-2010 09:25 PM
Gordon Killebrew has a glovebox sized book on the codes and a set of ALDL plugs which make reading the codes and resetting relatively easy.
Sounds like you need to clean up the two front impact sensors.
IMPORTANT Make sure you disconnect the battery from the car for at least 15 munutes before attempting any repair work on the SIR system. You don't want to blow the airbag. $$$$$.
Have you ever read the codes on a car in this manner before? It will blink once then 2 blinks which is a code 12. It will do this 3 times then it will blink the codes. Each 3 times.
Good luck, John :cheers:
Don in VT 07-28-2010 05:45 PM
Thanks for all the help. We will fix the ground issue this winter
Aurora40 07-29-2010 08:14 AM
It takes about 60 seconds tops to read the codes before spending time fixing the wrong issue. You can ground the pin with a bent paperclip.
