-   -   Cam Cover Emblems (http://zr1.net/forum/showthread.php?t=8283)
LGAFF 06-16-2009 09:17 PM
Re: Cam Cover Emblems
Here is the emblem with the color 237 cut and pasted into the bowtie.....keep in mind it will be flat the color template has a pattern
http://i134.photobucket.com/albums/q...ff/Emblem1.jpg
Here is side shot of thickness.....this is prebend:
http://i134.photobucket.com/albums/q115/lgaff/side.jpg
Chance I may get the detail work done, have them sent to me and the paint the ring black with high temp.....they did tell me original paint is soft enamel on the OEM.
LGAFF 06-20-2009 10:44 PM
Latest update......
They are going to use the same enamel that was on the OEM emblem, I will then seal the emblem with ceramic paint when I receive.....I will also test the emblem under high heat.
Using the same as OEM paint allows them to color match everything.
The outer ring is being checked for width and will be adjusted if needed.
Christ this is a pain in the A$$.....I hope this pays off!
Thanks for your patience and support!:hello:
DaveK 06-20-2009 11:10 PM
Thanks for all your efforts. I know that the members will appreciate it - I certainly do!
VetteMed 06-20-2009 11:20 PM
Thanks for the updates on this project - can't wait to see the finished product!
Pete 06-21-2009 12:19 PM
Lee, for the price i think they look awesome :thumbsup:
Will clear coat yellow with engine heat?
If the OE paint held up for 15 years i would think these will hold up for at least 5.
Pete
"Beggers can't be choosy"
LGAFF 06-24-2009 08:54 AM
Here is the update: they are retooling
Here is the order information:
Die struck brass soft enamel emblem
2.5"
Dying black plating
Curve as the sample
Gold paint on the cross
Wider border
2 cut-out
Estimated finish date July 3rd.
limey 06-24-2009 10:07 AM
lee,
I'll take 20 emblems when they are finished, off course , this depends on the likeness of the OEM's. I do like the way the vendor and yourself keep going back and working with the problem, i think this will only benefit everyone.
Kurt
LGAFF 06-24-2009 10:16 AM
anyone have a heat gun to check how hot the cam cover gets?
I am going to test them coated in cermaic and uncoated to see how they do....the paint used on these is the same as OEM.
flyin ryan 06-24-2009 12:53 PM
Thanks again for your effort Lee :thumbsup:. As far as how hot the cam cover gets...kind of an open question to some degree. If a guys in Florida & his Rad is dirty, could run around 240º/250ºF, where as a guy in your neck of the woods with a proper running temp. Zee would be more like in the 200º/215ºF range. So how much of a factor do you want to build in? If the emblem can handle upwards of 250ºF, that's pretty warm already...would be nice to have a used/beat-up emblem to use as a test mule to fire up.
LGAFF 06-24-2009 01:01 PM
soo if I leave it at 350-400 for 2hrs...,,that would be a solid test? Any thoughts?
