Re: TB removal and then some!!!
4 Attachment(s)
Pic #5....the new unit...
Pic #6...with oil cooler... Pic #7...LS of oil cooler lines up with bracket holes on the new unit... Pic #8...RS of cooler need to elongate the holes slightly as mentioned above to fit....but again the new unit does have provisions for oil cooler installation.... And thank you again Craig for the comments....very much appreciated....:):) Attachment 10592Attachment 10593Attachment 10594Attachment 10595 Sent from my SM-G965U using ZR-1 Net Registry mobile app |
Just leaving the radiator shop....not worth the time to get the condenser pressure tested....as he can only put 15 lbs of pressure on the unit...and the condenser has way more pressure pass through it....unless there was obvious staining on it....there probably is no major leak....and if there is a minute leak...he would not be able to determine that....so it looks like I may go with the replacement unit. He also advised against painting the fins on the condenser or oil cooler....as I was also thinking those thoughts myself...[emoji16]
Called a Automotive AC repair shop and they basically said the same thing....just blow some compressed air in the opening...leaning towards using the new unit....but still may attempt to clean the condenser out like I did the oil cooler as per Phil....:)
6 Attachment(s)
Tumble...tumble.....tumble....that's part of what has been going on for the last few days....finally unboxed my tumbler and put it to good use....also been purchasing some radiator cushions the last few weeks....so I'll have what I need when I put the cooling system back together....might have to modify one or two of them using the new A/C condenser...glad to have some extras....[emoji16][emoji16]
Pic #1...magnet making it easy to fish those parts out... Pic #2...may as well do some ZR-1 hardware as well....since I'm also doing the 74 hardware.... Pic #3....some hardware for the 74....to be polished in the next stage... Pic #4...first cleaning.... Pic #5...years of grime... Pic #6...so far.....looking good....cleaned and protected for future use...Attachment 10669Attachment 10670Attachment 10671Attachment 10672Attachment 10673Attachment 10674 Sent from my SM-G965U using ZR-1 Net Registry mobile app |
6 Attachment(s)
Well its been 2 years and going on 4 months since the 94 last ran. Since the 74 is now home and I'm in the process of getting the garage and basement reorganized, it is time to get ready to get the 94 running again.
Radiator, oil cooler and condenser are still out of the engine compartment. Still would like to do some additional cleaning before reinstalling everything. Also giving some thought to changing out the thermostat, since I have better access. Have to check my records and see if it was changed before. Also have Jerry's new oil cooler lines to install. And maybe thinking about back flushing the evaporator, maybe not. So when you have time to do things, you do the little things to, such as cleaning up the clamp that secures the AC line along the front rail. The cable or hose clamp had some corrosion inside of the rubber part and on the metal part as well. Some soaking, sanding and paint and rubber dressing makes them look good again. This particular clamp is hard to find, it appears that most of the parts houses don't stock this particular part # and some of the other places require a business account to purchase. They do make them in a number of sizes and I'm sure for those that need replacing, a close replacement can be used. Looking to have the Z running sometime this month. I do miss driving the 94, but with so much going on with my other projects, the time has and is flying by....[emoji16][emoji16] Pic #1 after cleaning Pic #2 before paint and rubber dressing Pic #3 clamp painted and hanging out to dry Pic #4 rubber dressing applied Pic #5 back together and ready for service Pic #6 just another viewAttachment 12794Attachment 12795Attachment 12796Attachment 12797Attachment 12798Attachment 12799 Sent from my SM-G981U using ZR-1 Net Registry mobile app |
Glad your back on the board Tom and sharing some attention on the 94.
Good to see you back Tom! As always, great job:)
How is the 74 running now that it is finished?
