Re: Thoughts on backfire?
The modified PROM is back in the car. Backfire problem is solved. Which leaves me with an entirely new issue...
The fuel that is now being added on deceleration is manifesting itself as a huge puff of gray smoke being blown out of the tailpipes. It is most evident a moment or two after an acceleration run, when I have mostly or completely lifted off the throttle. Can't decide yet which is more embarrassing: the backfiring or the smoke. The challenges of modifying this car are really starting to wear on me. |
You run it to Closed Loop?
Got a data log program? |
DFCO could clear this up, if you get it enabled quickly enough.
Glad you got the backfire fixed, reducing backpressure/scavenging characteristics can affect a lot. Glad Mark got your fueling correct to eliminate the issue. |
On my experiences with DFCO. On stock calibrations that a work with, there is a delay timer that starts counting the moment the PCM/ECM detects a closed throttle. On my trucks its set by GM to 4 seconds, so 4 seconds after I let off the throttle, DFCO kicks in cutting the injector pulsewidth essentially cutting fuel to the engine. When DFCO does engage, there is a marked increase the rate of deceleration, compared to when the engine is idling with the throttle closed. I was running LT headers and 4" sidepipes at the time, and after the computer entered DFCO, I could hit throttle and a loud "CRACK" would be heard as the fueling recommenced as DFCO was dropped. Here are a few DFCO parameters from an LT5 ECM DFCO RPM Enable Threshold DFCO RPM Disable Threshold DFCO MAP Enable Threshold DFCO MAP Disable Threshold DFCO RPM Decrease Disable Threshold DFCO Enable Delay DFCO Enable TPS Threshold Hysteresis DFCO Enable Coolant Temp Threshold DFCO Enable Vehicle Speed ThresholdMy question is, can anyone tell us what the DFCO Enable Delay is in a stock calibration? What I am wondering about is that you were getting a backfire as soon as you depressed the clutch. Unless the DFCO Enable Delay is set to "Zero" seconds, DFCO engagement "shouldnt" be the source of your push clutch then immediate backfire issue. I could see DFCO being an issue during coast down from high rpm, but my suspicion is that the part of the "anti-back fire" calibration mods that you received today were mostly fueling, possibly spark, but not DFCO. I can 100% understand a DFCO engagement causing a crackle, but not as soon as the clutch pedal is pushed.(again unless the DFCO enable is set to zero seconds) Knowing the stock enable times would help. If mu suspicions are correct and DFCO is not the primary issue here, you should be able to have a non-backfiring ZR-1 that also doesnt spew gray smoke. This would be accomplished by using whatever cal. changes were used that stopped the backfire, in addition to a more thorough calibration of the DFCO settings. This however, may be beyond the capabilities of mail order tuning. DFCO recalibration is very trying at best, as aposed to Enabling or Disabling its function entirely. On GM trucks with the tow/haul switches, I can take have the truck shift normally when the tow/haul button is off. But when you press the T/H button, I change a whole slew of ECM/TCM tables and make the same truck accelerate harder, shift harder(bark tires if that is desired) all with the flick of the T/H button. Many tuners, call this collective group of numerous transmission parameter changes their "Tow/Haul *** Mod", rather than describe each and every change that was made to the entire calibration. My point here is that it is much easier to decsribe a group of calibration changes as "Tow/Haul ***" or "Anti-BAckfire" modes to a customer, than it is to list the 10's or even hundreds of changes you made, esp. when it really wont make a difference. This may, or may not be the case with Mr Haibeck's marketing of his excellent ECM calibrations and the hard work and dedication he puts into all the work he does for his customers.. But if I were in his shoes, it's what I would do. It simply keeps phonetime, and internet time to a minimum. It would be different if these professionals got paid for their question/answer sessions, but usually they dont. (eg. It almost took me an hour to formulate and type this post, but theres a difference between business and pleasure) Sorry for the book, but its a complicated issue IMO. |
Stock is 250ms for Delay, 3 sec for a repeat. But Hog, DFCO has been disabled. So now there's fuel continuing to flow even while throttle is closed. Don't forget that when you hit the throttle, you are invoking Acceleration Enrichment. Too big a pump shot and...
