-   -   Input on hot start failure (http://zr1.net/forum/showthread.php?t=29306)
onetinsoldier 07-18-2018 08:17 AM
Re: Input on hot start failure
Originally Posted by Ccmano (Post 281489)
Or simply a bad or misadjusted throttle position sensor. The system looks for a proper throttle position reading as part of the starting sequence.
H
:cheers:
I use a digital ohm meter , its .54 !
XfireZ51 07-18-2018 09:43 AM
Ok.
1. When u turn ignition ON, engine COLD you hear both pump energizing, Correct?
2. When you turn ignition ON, engine HOT , you hear both pumps energizing, CORRECT?
3. Have u determined at what coolant temp, the warmed motor will finally start at?
onetinsoldier 07-18-2018 03:08 PM
well after replacing the crank sensor and no luck , I tried another crank sensor , it seems to have solved the problem ! ....hopefully !
