Re: Searching for a Fuel Line Clip
http://www.etsy.com/listing/16043993...?ref=related-1 Speaking of google, I saw that their stock hit $1000 a share.......man I wish I invested in their stocks years ago as I would have ordered a C7 Stingray as my daily driver if so. |
I just finished painting your engraving. You might want to take a break on the PO Box vigil for a few more days. I'll be mailing out to you on Monday. Jim, Thanks for the kind words. Pics from both of you would be great! Again thanks, Carter :cheers: |
I received the fuel line clip today. I decided to try installation right away. Things did not go well. Nothing to do with the clip though. When I tried to take the nut off, the stud came out instead. I'm thinking of using epoxy when screwing it back in. When I took the old broken clip off, I dropped it into the engine compartment. It made a sound like it hit the exhaust shielding. It did not fall to the ground and I can't see where it went. I'm afraid it may be inside the shielding and if I leave it there it will melt when things heat up. One day I'm going to jack the car up and try to find the clip from under the car.
Did you order the vintage button from the link? They only have 1 left. Maybe Carter can make you some billet center caps for your wheels with this design? :p |
I just retightened it and installed the bracket with no issues. Be sure to orient the two halves of the billet fuel line bracket by mating the two sides with the RED mark on each half. Thanks again, Carter :handshak: |
Remember it's only money..... |
You should be able to get the two halves to come together to make the 87 look better. Let me know if any issues, Carter :cheers: |
Here's my bracket that I got from Carter last week. The quality of his work is extremely nice! It was more difficult than I expected to line up the fuel lines to where they would sit in the bracket correctly but once in place they look fantastic! Here goes a couple of pics...
http://i18.photobucket.com/albums/b1...psff59c24c.jpg http://i18.photobucket.com/albums/b1...ps5c073fd4.jpg http://i18.photobucket.com/albums/b1...psfcae5370.jpg |
Carter,
Thanks again! I finally got around to installing the clamp/bracket today. It did not work like the photos in the post above, but I was able to get the clamps to close flush after pulling the entire end part past so that the bracket is holding just the steel braided part line. No matter what I did (red marks matching and all, even flipped around thinking one opening was larger) it would not clamp flush. |
