-   -   Thermostat (http://zr1.net/forum/showthread.php?t=27640)
A26B 03-30-2017 07:48 PM
Re: Thermostat
Why do you want a 160F t-stat?
What do you expect the result to be from a t-stat that opens earlier, i.e. lower temp?
XfireZ51 03-30-2017 08:04 PM
Re: Thermostat
Read this thread on thermostats. Installation of a Fluidyne radiator caused cooling issues in particular in cold climates. As Gerry states a bypass hole provides more rapid cooling.
You can follow the results I got here:
http://zr1.net/forum/showthread.php?...ght=thermostat
5ABI VT 03-30-2017 08:31 PM
Re: Thermostat
Cooler temps on the freeway.
XfireZ51 03-30-2017 08:41 PM
Re: Thermostat
You really want to run at >-= 80C for coolant temps. That's where the calibration is in Closed Loop and LEARN is ON.
5ABI VT 03-30-2017 09:36 PM
Re: Thermostat
don't necessarily need 160 just would prefer something a little cooler than the oem stat.
XfireZ51 03-30-2017 10:22 PM
Re: Thermostat
I guess the question is still "What's the result u r looking for?" If the motor is running at about 185F-190 or so, that's where it needs to be.
Livin' in the 80's 03-31-2017 04:51 PM
Re: Thermostat
I ordered the Stant 14068 thermostat and it doesn't look like the one that is posted. Here is a picture of it. Should I still install it or should I try to order it from somewhere else? The first three pics are the one I ordered and the last is the one that is on ZR-1 Specialist website. I don't want to do this job twice or screw the car up. Thoughts?
http://i653.photobucket.com/albums/u...psmblareep.jpg
http://i653.photobucket.com/albums/u...psmyassatz.jpg
http://i653.photobucket.com/albums/u...pss4yfhfwy.jpg
This is what is posted on Jerry's sight:
http://i653.photobucket.com/albums/u...pslgm2zx0o.jpg
A26B 03-31-2017 06:10 PM
Re: Thermostat
Don't install the one in your 2nd & 3rd photos.
Getting the wrong part in the right box is not uncommon. Between that problem & incorrectly identifying parts as LT5 compatible, it can be a real problem sometimes.
XfireZ51 03-31-2017 06:59 PM
Re: Thermostat
I bought a thermo from Jerry just to avoid any "agida" later on.
HAWAIIZR-1 03-31-2017 07:25 PM
Re: Thermostat
Originally Posted by Dynomite (Post 259400)
Stants from Jerry or Marc.
I never drill holes in the Stant 180 deg Thermostat as that offers very little (1.6%) increase in coolant flow.
LT5/ZR-1 Fluids
RADIATOR COOLANT
You want to only use the green coolant. They have it at Napa and it meets 1825M GM Spec.
For Zerex the first gallon is called Regular Green Coolant (GM 1825M), the second gallon is called Original Formula (GM 1825M). Zerex ZXRU1 is 50-50 and Zerex ZX001 is undiluted. The third gallon is NAPA coolant (GM 1825M).
http://partimages.genpt.com/partimages/213991.jpgORhttp://ecx.images-amazon.com/images/I/31jb-ZubjrL.jpgORhttp://partimages.genpt.com/partimages/213967.jpg
NAPA
All I could find here in Japan at the Navy base Autoport are these:
https://uploads.tapatalk-cdn.com/201...88462062cb.jpghttps://uploads.tapatalk-cdn.com/201...8ed0d0a2f3.jpghttps://uploads.tapatalk-cdn.com/201...0bcfb57218.jpg
None of them state GM 1825M. I'll have to check manufacturer's website for more details.
