-   -   Electrical question: is this supposed to be here (http://zr1.net/forum/showthread.php?t=35316)
1991 Corvette ZR-1 05-27-2024 08:55 PM
Re: Electrical question: is this supposed to be here
Sounds like one of the lifters is not happy. How old is the oil? Is the level within the hash marks on the dipstick? I have an old beater four cylinder that makes the exact same lifter chatter noises if the oil gets too low or the oil is past due for changing.
Marc Haibeck 05-27-2024 10:31 PM
A lower pitch click could be from the cams snapping over center due to slack in a secondary timing chain. There must be at least 10 psi of oil pressure to keep the chain tensioned.
The same sound could also be caused by a leaky check valve in a chain tensioner. Try to identify the source as from the left or right bank. The retainer for the check ball could be loose. If so, the tensioner can be repaired rather then replaced.
Tim555 05-28-2024 07:54 AM
Oil was changed in February. Level seemed good but I?ll check again.
Tim555 05-28-2024 07:56 AM
Thanks Mark. I?ll take a closer listen to it and see which side it is coming from. Does the engine have to come out to repair or replace a tensioner?
davegarcia 06-11-2024 04:45 PM
The light for the airbag on my 1990 z, and the seatbelt light on the dash come on while driveing the car. Never has done that before. Unpluged the battery to see if that would reset the computer. Lights are still on after hooking up the battery. Any ideas what could be the problem? Thanks in advance, zr1dave@hotmail.com
hotroddaddyo 06-11-2024 07:26 PM
https://www.corvetteforum.com/forums...elt-light.html
