-   C4 ZR-1 Parts For Sale / Wanted (http://zr1.net/forum/forumdisplay.php?f=10)
-   -   FS: Single Fuel Pump Conversions for LT5 (http://zr1.net/forum/showthread.php?t=33899)
Flyman 27 04-20-2022 06:55 AM
Re: FS Single fuel pump conversion for LT5
Thank you for the nice words, it is greatly appreciated!
Matt B 04-20-2022 10:17 AM
Will you be at the gathering?
Flyman 27 04-20-2022 01:08 PM
No, not this year.
Flyman 27 04-28-2022 07:14 AM
Matt B,
I can't send you a private message until you clear out your old messages, your account is totally full.
Dan
aafc 04-28-2022 12:49 PM
Well after having trouble with the stock fuel system (two pumps) in my ZR-1
I was going own make my own based on marks write up. But Flyman 27
offered single pump setup for the ZR-1. Well that made It easier for me a
already made system that I could install with out to much trouble (getting
out the two pump system).Brought the single pump system and installed
It. Works great, but I noticed that the fuel pressure would drop as soon as
I turned off car. Not a big deal, turns out there is no drain back valve . OK
now my engine is a 368 cu.in. motor with 12 to 1 compression. Flyman 27
said just install a check valve from tank output to the engine.
And problem solved, holds pressure starts in about 3-4 seconds
and pressure holds for restart.
I'am very happy with this system and would recommend it if your having
issues with dual pump system.
1990 white/black # 2546
one of a few 4l8OE EQ ZR-1's
Jagdpanzer 04-28-2022 05:43 PM
I'm interested
PM sent
Matt B 04-30-2022 12:41 AM
Originally Posted by Flyman 27 (Post 332290)
Matt B,
Dan
Done. Sorry, it all came together this time [emoji23]
Matt B 05-07-2022 01:02 AM
Got mine today. Thanks Dan for making, thanks Marc for bringing it [emoji3]
Looks awesome, can't wait to install it. Definitely great work!
efnfast 05-07-2022 07:19 AM
I saw Matt's at BG, what a beautiful job. Looks factory.
Flyman 27 05-07-2022 04:34 PM
Thank you for the kind words.
Dan
