-   -   Jeep D44 4.10 gears (http://zr1.net/forum/showthread.php?t=26762)
Jagdpanzer 07-28-2016 01:33 PM
Re: Jeep D44 4.10 gears
Dave is correct about our D44 using D60 style 29 spline pinion.
I have corrected my privious post.
5ABI VT 08-02-2016 12:25 AM
My 93 Base LT1 car came with these gears (4.09) . Caravaggio was the one who worked on it and it uses the jeep stuff. Not sure of the details. I built a high rpm LT4 and dropped down to 3.73s so I tossed it all out. Held up really well. about 7 years... hundreds of drag strip passes and hundreds more street racing. Never had an issue.
XfireZ51 08-02-2016 07:26 AM
Dynomite,
I think this thread would make a great "STICKY" thanks to Dave, Phil, and 5AB.
WVZR-1 08-02-2016 09:48 AM
Originally Posted by XfireZ51 (Post 245831)
Dynomite,
I believe that "5ABI VT" build was an earlier conventional D44 with the 26 spline and NOT the later JEEP that you mentioned. There's much that indicates that, 4.09 mainly - his D44 might have been from a Jeep application but much "older" original 216mm ring gear builds.
XfireZ51 08-24-2016 10:22 PM
Ok Phil. U got me at a weak moment. Ordered the MOPAR gears. Anything different about the install kit?
-=Jeff=- 08-24-2016 10:35 PM
Did you order the speedo correction gears from Marc too?
XfireZ51 08-24-2016 10:38 PM
No. I currently have the stock speedo gear in there and it reads ~4-5% slower now.
Jagdpanzer 08-25-2016 09:35 AM
The Viper set uses a crush sleeve for setting the pre-load on the pinion bearings.
Also, the ring gear is a bit larger and in some cases the bottom the housing requires minor clearance grinding.
Which install kit did you get?
XfireZ51 08-25-2016 10:22 AM
Haven't gotten one yet. That's why I asked. Not sure when I'll put the gears in.
All depends on who's available to do it and when. Thought I would take advantage of the price tho.
Dynomite 08-25-2016 10:23 AM
Dynomite,
DIFFERENTIAL
Jeep D44 4.10 Gears
LT5 Added Systems (Differential Case Drain)
Clicking and rust on Spindle Shaft TIPS
LT5 Engine and Differential Lubrication Discussion TIPS
Dana 44HD TIPS
Going from 3:45 to 4:10 Differential
Differential case drain
Less intrusive differential case drain
Differential removal
Differential fluid change
4.10 gears pictures
Viper gears
Viper Parts
Dana 44
