Re: TB removal and then some!!!
3 Attachment(s)
So taking a suggestion from Jerry to use a 6 point socket or box wrench to remove the oil hose connectors.... I ordered 2 sockets from Amazon....assuming they were metric....I ordered a 28mm and and
29mm 6 point sockets....finally got them this AM....(first set got lost).... Now this may be common knowledge too many.......the 28mm is too small and the 29mm fits....but not 100% snug fit.....tried the 29mm and just didn't feel right....sprayed down the connectors with PB Blast and then used a 1 1/8" 12 point socket and a 12 point 1 1/8" box wrench (I don't have 6 points in that size)....they both fit perfect and 100% snug....no movement.... So with my trusty hammer....broke both loose and removed... Again....may be common knowledge...but for those attempting this for the first time....hope this helps... The following pics show the tools used and I tried to take close ups of how the connector fits in both sockets... First pic....what I used... Second pic....the 29mm 6 pt socket... Third pic....the 11/8" 12 pt socket....Attachment 10368Attachment 10369Attachment 10370 Sent from my SM-G965U using ZR-1 Net Registry mobile app |
A word to the wise regarding installation of the new fittings; If you use teflon tape, that's OK, BUT teflon significantly reduces the friction of the interference fit of tapered pipe threads. Do not overtighten as it WILL crack the Oil Filter Housing. I have used it for decades and will continue, but you have to know when to quit tightening, especially when screwing large fittings into aluminum castings.
Loctite 565, recommended, is a paste sealant that works well. It is much like a good plumbers thread dope which can also be used. Not quite as slippery as teflon so maybe a bit safer to work with. |
4 Attachment(s)
More progress today....radiator drained....coolant crossover pipe removed....accumulator and main AC hose set also removed. ..
Stand corrected somewhat on the coolant hose replacements that I have....did a trial fit and they will fit over the pipes....but still appear to be a tad shorter....may just go to the store and see if they can match 2 90* hoses and then I'll cut them to fit.... Also may be common knowledge....but we all know what it's like to remove hoses from the pipes....I spread the hose a little to shoot some PB Blaster inside and work it around.....hose slides off without cutting.... Some pics ...Attachment 10373Attachment 10374Attachment 10375Attachment 10376 Sent from my SM-G965U using ZR-1 Net Registry mobile app |
4 Attachment(s)
The coolant pipe hoses . .Attachment 10377Attachment 10378Attachment 10379Attachment 10380
1 Attachment(s)
Amount of Pag oil from my accumulator.....so looks like the evaporator may also be somewhat dry...since the new compressor has 4.1 oz from the factory...and our system requires 8 oz give or take a
.10 .....looks like I'll be adding about 3.8 oz to the new accumulator during the rebuild...which will give me 7.9 oz in the system....[emoji16]Attachment 10381 Sent from my SM-G965U using ZR-1 Net Registry mobile app |
2 Attachment(s)
Call around to a few hydraulic hose companies today and even went to see one....apparently no one does automotive lines....as they don't have the ability to crimp the hoses to the tubing....I have one other company to check out....otherwise I will just reuse what I have....my concern was with this one crimp that was worn down from resting again the pipe...blew compressed air through....although not pressurized....and no leaks that can be determined....they are Goodyear USA made hoses and even with the one spot that is worn....still look to be in decent shape...just did a slight cleanup....and will do a respray...and they should do the job...Attachment 10382Attachment 10383
4 Attachment(s)
Success.....radiator out....fans next...will get the radiator pressure tested....
I imagine these lower rubber radiator supports are standard C4....are they still available???Attachment 10384Attachment 10385Attachment 10386Attachment 10387 Sent from my SM-G965U using ZR-1 Net Registry mobile app |
Not trying to spend your money, but.... Now’s the time to install an all aluminum radiator. Do you really trust the 25 year old plastic tanks on the original??? Even if it passes a leak test? |
But that will have to wait for another week....we are taking a vaca next week[emoji4] Sent from my SM-G965U using ZR-1 Net Registry mobile app |
3 Attachment(s)
More progress today before taking some time off....fans are out. .and now so is the lower radiator support...
Have to think out my cleaning strategy when we return...next week will give me time to do just that!!! Broke one of the tabs for the wire loom in pic #3...still useable if unavailable....... but I imagine that they may still be available from the dealer..Attachment 10393Attachment 10394Attachment 10395 Sent from my SM-G965U using ZR-1 Net Registry mobile app |
4 Attachment(s)
Lower radiator shroud is out....Attachment 10396Attachment 10397Attachment 10398Attachment 10399
4 Attachment(s)
Just did a quick wash on the lower shrould....pic #1...the part #....
Pic #2....one of 5 10mm bolts and nut washers that attach the front of the lower shroud to the top of the center air dam.....passenger side in pic #2 & pic #3 does not come out when loosen....it stays in the shrould....as the metal bar shown in pic #3 overlaps that bolt....looks like metal bar in pic #4 took a beating in its earlier days from the front air dam taking some rough bumps....Attachment 10400Attachment 10401Attachment 10402Attachment 10403 Sent from my SM-G965U using ZR-1 Net Registry mobile app |
6 Attachment(s)
Fans went from looking like this in pic #1 to like this in pic #2....pic #3 shows one of the radiator rubber supports...it appears that this system was removed before....as the front of both rubber supports where the condenser sits....was reformed during installation...as the time wasn't taken to make sure the parts sat correctly in the support....pic #4 shows a first cleaning of the supports...plus you can see how the rubber was deformed...tried in pic #5 to reform the support....but then thought it might work out better as shown in pic #5...#6...& #7.....just taped to the condenser itself....we shall see...will probably go with the poly version...sine the OEM rubber versions are not available...
Also getting the AC Compressor manifold hose assembly repaired...should be completed in a few days...interesting on how they are doing the repair....[emoji16][emoji16]Attachment 10428Attachment 10429Attachment 10432Attachment 10433Attachment 10434Attachment 10435 Sent from my SM-G965U using ZR-1 Net Registry mobile app |
1 Attachment(s)
4 Attachment(s)
Accumulator holder redone with new accumulator installed....pics #3 & #4 before pics....getting ready for paint...[emoji16]Attachment 10437Attachment 10438Attachment 10439Attachment 10440
That accumulator will easily polish up like chrome... 😋 |
Also ordered a new fan motor, as one of my fans is making a worn bearing noise when turning by hand. And taking your advice for a new radiator...will order one soon....:):) |
Just pick up a couple buffs for your electric drill and a stick or 2 of compound
at your local hardware store or Home Depot. Not too much $ and easy to do. (before you put it in the car...) Recommend a DeWitts 2 row radiator, 32-1139090M, shop around for best price with free shipping... |
Tom,
I have the proper and new De Witts Radiator in my stash for your car if you need/want it. 90M new in box. current price 569.00+ ship less discount for you taking pictures of Ruby at Carlisle for me Hows $400.00 and a visit? Let me know. Marty |
Glad to take those pics for you.:):) Even if I didn't purchase, a visit is still in order....just been crazy busy with the 94 and also trying to wrap up the 74 by the end of October. Thanks, will chat soon....:) Tom |
4 Attachment(s)
Did more fan assembly work today....just thought I would clean everything up and reinstall....but that soon changed....ended up painting everything after the cleaning...
Pic #1....fan assembly apart with replacement fan motor going in... Pic #2...3 & 4....also pulled other fan assembly apart to paint original motor... Attachment 10450Attachment 10454Attachment 10455Attachment 10456 Sent from my SM-G965U using ZR-1 Net Registry mobile app |
3 Attachment(s)
The one fan bracket or holder that the fan sits in accumulated all of this crud in pics #1 & 2 over the years....took a SOS pad and scrubbed it all down.... pic #3 shows how clean and smooth it came out....and that when I decided to paint....as the finish was really dull after cleaning....Attachment 10457Attachment 10458Attachment 10459
3 Attachment(s)
Had to think outside of the box with both sides painted and needing to dry without anything touching in pic #1....worked great.....
Pics #2 & 3 are the fan assembly with the new fan motor installed....came out looking decent....other assembly is almost together......just needs more drying time....Attachment 10460Attachment 10461Attachment 10462 Sent from my SM-G965U using ZR-1 Net Registry mobile app |
3 Attachment(s)
Fan assemblies are completed....debating on whether to refinish the fan shroud....if I go with black...then the finished pattern is gone....have to see if there is a paint that will duplicate the original finish...[emoji16][emoji16]Attachment 10463Attachment 10464Attachment 10465
What do you use the plunger for??? 😋 |
What do you use them for? ;) |
Big John We know what you use it for (and other things I won‘t mention...) but I‘m asking Tom and what on the ZR-1 he uses it for... 🤣 |
Tom did you ever find that missing 13mm socket?
6 Attachment(s)
Just picked up my AC manifold hose assembly from being repaired @Kenco Hydraulics in Hatfied PA.
Did a search in my area and they were the only ones to take on the repair. They did an excellent job and made some improvements at the same time. You will notice that the accumulator rubber hose is now shorter and there is a slight bend in the metal tube...where there wasn't before. Also JIC fittings are now implemented into the assembly....making it much easier to clock the connections during reassembly on the car. Even though the accumulator rubber hose is shorter....measurements were taken beforehand to make sure that the actual length of that part of the assembly were indeed correct. I think the main concern when reattaching on the car is to make sure that the hose does not rest against the crossover coolant pipe as it did on my engine....causing the wear problem that resulted in repairs. Again extremely happy with the work that they did. They are also open to doing the same for anyone who needs this type of repair....just let me know and I will give you the info... As you can see the repaired assembly in the first 3 pics with the replacement hose and the JIC connections....the next 3 pics show the old hose that was cut off and what the end looked like from resting against the coolant crossover pipe for 25 years....Attachment 10480Attachment 10481Attachment 10482Attachment 10483Attachment 10484Attachment 10485 Sent from my SM-G965U using ZR-1 Net Registry mobile app |
What are JIC connections? |
JIC fittings, defined by the SAE J514 and MIL-DTL-18866 standards, are a type of flare fitting machined with a 37-degree flare seating surface. JIC (Joint Industry Council) fittings are widely used in fuel delivery and fluid power applications, especially where high pressure (up to 10,000 psi) is involved.
All I know it is going to make it a breeze for install....it was recommended to hook up the compressor then the accumulator then tighten the JIC connection closest to the accumulator and then tighten the JIC connection closest to the compressor....no sealant of any type is required or recommended....:) |
2 Attachment(s)
Going through parts today and rearranging the parts room....found something that I misplaced awhile ago....
Will install one day.... NOS RH Tensioner Kit....purchased years ago... If anyone needs a copy of the instructions....let me know....will be glad to post them up....Attachment 10491Attachment 10492 Sent from my SM-G965U using ZR-1 Net Registry mobile app |
3 Attachment(s)
Just made a run to Harbor Freight to take advantage of expiring coupons....
So check these out...pic #1... this large light on sale with coupon....works really well when under the car or in dim light areas...better than the old drop lights IMO....and it has a magnetic base....the small light also on sale with coupon... works well for many uses... Pic #2 is the free light that you get with coupon... And I couldn't pass up pic #3... just what is needed for trips in the Vettes...just in case...I always carry this and that....but this just makes it easier and it was only $5.99 and with my 20% coupon...now $4.79 [emoji16][emoji16]Attachment 10516Attachment 10517Attachment 10518 Sent from my SM-G965U using ZR-1 Net Registry mobile app |
5 Attachment(s)
Figured I run by Ace Hardware to look for 2 bolts for the cooling fan to attach to the fan shroud....I was missing one and those small 7mm head bolts used for the upper and lower radiator shroud attacement....Ace was a bust...went over to Lowes which has a better Hillman Automotive selection than HD....IMO and found exactly what needed...
Also received my shipment of rosebud clips for the fan conduit harness connection to the fan shroud....success...[emoji16] Pic #1 is the bolt used for attaching the fans to the fan shroud....10mm head bolt as shown in pic #2...replacement bolt is on left side in both pics...although slightly shorter @25mm length instead of a 30mm length (stock size)...should work just fine... Pics #3 & 4 show the small 7mm head bold (which both a 7mm and 9/32 socket will fit) that is used for the radiator shrouds and also attaching the oil cooler to the condenser....replacement bolt is also on the left in both pics....should be a 15mm length (stock size)...but this is a 20mm length...which should also work just fine... Also received a rosebud shipment pic #5 for the fan conduit harness attachment for the fan shroud...Attachment 10519Attachment 10520Attachment 10521Attachment 10522Attachment 10523 Sent from my SM-G965U using ZR-1 Net Registry mobile app |
3 Attachment(s)
An update on the 7mm screws in pics #3 & #4...
I found this bag of trim screws in pic #1....that must have had and they are a great match and the correct 15mm length....with the 7mm bolt head.... Pic #2...Left bolt is stock, center bolt is the Hillman bolt...and the right bolt is the trim screw from the above pack... Poc #3...They are all 7mm head screws...same order as mentioned above.... Attachment 10540Attachment 10541Attachment 10542 Sent from my SM-G965U using ZR-1 Net Registry mobile app |
4 Attachment(s)
Been checking out the radiator cushions for the ZR-1 and as been mentioned they are hard to find the rubber units....although poly replacements are available....I can reuse my stock ones....if need be...
So I checked out what if anything was available and found the following.... Plus found some additional fasteners and radiator shroud bolts..... Pic #1....these are to my knowledge the original LS & RS Upper radiator supports... Pic #2...another view... Pic #3...support on the left is from the 94....support on the right is a purchased part....the configuration is opposite.... Pic #4...another view from a different angle...again opposite orientation.... purchased unit on the left....original on the right...Attachment 10547Attachment 10548Attachment 10549Attachment 10550 Sent from my SM-G965U using ZR-1 Net Registry mobile app |
4 Attachment(s)
Pic #5...here we have the originals on the top and two NOS units I found....they are the exact orientation...as they should be...
Pic #6...another view... exactly the same.... Pic #7...now here is the bottom support...unit on the left is from the 94....unit on the right was purchased... the orientation although on the same side...is also off to where this may not properly fit... Pic #8...you can also notice the difference in the orientation from the bottom side....only thing I can think of..... is that...this is from an earlier C4 and being sold as a 90-96 part....Attachment 10551Attachment 10552Attachment 10553Attachment 10554 Sent from my SM-G965U using ZR-1 Net Registry mobile app |
