10-04-2005 | #1 |
photo and dimension of damper
I need a front, side and rear photo of the LT5 torsional damper.
I also need the inside diameter of the shaft area or outside diameter of the crankshaft where they mount together.
Mike 427 cu in LT5 [URL="http://zr1mk.weebly.com"]http://zr1mk.weebly.com[/URL] |
10-31-2005 | #2 |
Re: photo and dimension of damper
I received the pictures I was looking for. Next question.
Did the World Challenge ZR1s use the stock engine torsional damper or an aftermarket unit?
10-31-2005 | #3 |
Didn't think there were any WC ZR-1's. Just L98 cars.
11-01-2005 | #4 |
http://www.speedvisionwc.com/2001/rat/gt-qual2.html
http://zr1netregistry.com/ZR1_racingpictures.htm
11-01-2005 | #5 |
What the junk,... I posted in this thread earlier... where'd it go?
E-gnomes.
"Mr. President, we must not allowwww... a mine shaft gap!!" -General Buck Turgidson 1994 ZR1 - White on Black |
11-01-2005 | #6 |
I know you did too because I read you message.
So whats going on?
11-01-2005 | #7 |
E-gnomes I tells ya. Little short fat buggers with peculiar hats that run around at night screwin shyt up all over the internet. I think Wadsworth is their leader.
"Mr. President, we must not allowwww... a mine shaft gap!!" -General Buck Turgidson 1994 ZR1 - White on Black Last edited by Patton; 11-02-2005 at 12:29 PM. |
