03-14-2009 | #1 |
Vacuumn line ?
Should the vac line on the driver side that runs from the side of the plenum to under the plenum be able to hold vacuum?
03-14-2009 | #2 |
Re: Vacuumn line ?
I almost positive it does, it has a check valve in the line from it.
03-14-2009 | #3 |
Re: Vacuumn line ?
The plenum is creating the vacuum source on the metal hard line from the PCV valves.
03-14-2009 | #4 |
Re: Vacuumn line ?
Jeff I think he is talking about the one that is in the middle of the runners on the plenum.
03-14-2009 | #5 |
Re: Vacuumn line ?
Yes, I was......and duh......checked my other ZR-1 and it does. The line is repaired and will not haold, leaking where it was sleeveed with a rubber hose.
Thanks Guys
03-14-2009 | #6 |
Re: Vacuumn line ?
you might try a little black silicone . what i di is pull the rubber connector almost all the way offput a dab of silicone on the plastic line at the base of the rubber connector and as i put it back on kept turning it to get an even coating . then i just wiped off the excess.
