Old 08-10-2005   #1
bike01
Default High Idle on Start up
My '91 zr-1 will idle 1500 - 2000 rpm right from start up in the mornings and stay there until the car warms up. After it reaches operating temperature, the idle will drop down to about normal. Any ideas. Doesn't happen al of the time.
bike01 is offline   Reply With Quote
Old 08-10-2005   #2
RiceEatingZR1
RiceEatingZR1's Avatar
Default
I had a High Idle that turned out to be a Vaccum leak under the plenum, however my high idle never settle down to normal RPM's, it might be the ECM Chip do you have any after market chip?
RiceEatingZR1 is offline   Reply With Quote
Old 08-10-2005   #3
Kevin
Kevin's Avatar
Default
did the 91's have the same high idle problem as the 90's that went away if you changed the prom?
Old 08-10-2005   #4
zr1mom
zr1mom's Avatar
Default
Yes they did.
http://www.zr1netregistry.com/ZR1_issues.htm#2
ZR-1 Mom
Founder ZR-1 Net Registry
Founder ZR-1 Net
zr1mom is offline   Reply With Quote
Old 08-10-2005   #5
Default
Look for the part # on the mem-cal
I think this is the updated Chip # 16193416 for 91
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 08-10-2005   #6
Kevin
Kevin's Avatar
Default
Or you just just get an after market one from mark haibeck or someone like that
