Old 12-15-2008   #1
Default ZT-2 WB O2 Installed w Display
Installed just around Tgiving. Working great. Idle looks pretty good and its in Closed Loop.
Old 12-15-2008   #2
Default Re: ZT-2 WB O2 Installed w Display
Dom,
Did you install a separate bung or did you substitute the WB for one of the original sensors?
P.
Old 12-15-2008   #3
Paul,
Current ECM code doesn't support using WB as NB O2.
I'd be interested in getting WB output into ALDL
stream. Since you're in process of putting headers
on, I would suggest putting separate bung in collector.
Mine's on the passenger side next to NB O2.
This is really the only way to tune WOT IMO.
Old 12-15-2008   #4
Aurora40
Aurora40's Avatar
Looks good! So you leave it installed all the time? Also, is your idle < 500 rpm?
Bob Saveland
Former owner of #2517
Old 12-15-2008   #5
For now, it's installed and working all the time. I have power coming from
aux connectors under the console. Idle is right around 700.
Old 12-15-2008   #6
Zr1 Destroyer
Zr1 Destroyer's Avatar
Nice.....I did an AEM wideband on mine and like I it!
Zr1 Destroyer is offline   Reply With Quote
