Old 03-09-2008   #1
Default WB O2 Connections
If you have installed a WB O2 in your ZR, I'd be interested in knowing where you made the connections. Once I'm done with plenum and head port matching, I'll need to re-do WOT fueling, I am sure. I'll be using a Zeitronix ZT-2. With the display I'll be showing MAP, AFR, and TPS. Would like to know:
1. where you have grounded sensor?
2. connected switched power?
3. Todd told me there is a tachometer takeoff by the master cylinder
4. If your WB is permanently installed, which way did you route
cabling thru to cabin?
