Old 02-17-2008   #1
Default Another ? about cats
Putting headers on and looking at some cats.. any comments on these. Also going to 3.73 gears.
http://www.rpmoutlet.com/powercat.htm
http://www.performance-curve.com/ind...&ProdID=118 1
http://store.summitracing.com/egnsea...0&autoview=sku
Thanks
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 02-17-2008   #2
Sgreg
Sgreg's Avatar
Default Re: Another ? about cats
They all look decent but the difficult thing to evaluate is how well they cut emissons. No aftermarket cat is as effective as the factory version. I have the overpriced RT's and have had difficulty passing emissions in Texas. Can pass with a prom change but it is difficult. If you ask the reps for the various brands about emissions they will tell you their cat works. So you pay your money and you take your chances.
1991 ZR-1, Black, Black, # 541
Sgreg is offline   Reply With Quote
Old 02-17-2008   #3
Thanks that is the type of info I am looking for...I have found out the RTs flow around 620..and the MF about 595..
Steve
1990 Red/Red #1473
Old 02-17-2008   #4
Ccmano
Ccmano's Avatar
I used DynaTech Powercats (Jegs) on my old L98 setup and had the same situation, had to go back to original chip to pass emmissions.
Hans
90'ZR-1 #1461 Red/Black
05 C6 Z51 Red/Black Sold
Old 02-17-2008   #5
Nick
Where does that info come from?
Nick
ZR-1 Net Registry Founding Member #32 - lapsed...
Old 02-17-2008   #6
Aurora40
Aurora40's Avatar
Most of the freer-flowing aspect of "performance" cats comes from less or less dense media to flow through. The only way it could really be as effective and flow better would be if it were bigger than the OEM cat. If you've seen the OEMs vs bullet cats, that isn't even close to true. The other way it could flow better and be as effective would be if it had some better technology (like modern cats vs pellet-type cats). But there is no new/high technology in RT cats and the like that OEMs haven't already been using for years.
On many OBD-II vehicles, aftermarket high-flow cats will set off the check engine light or require O2 simulators, because the cat does a worse job of catalyzing and the post-cat O2 sensor can readily detect it.
Plus, bullet cats on long-tube headers move the cats further down the exhaust stream, so they will take longer to heat up and start working.
But most of us just need "just enough" catalyst to pass state emissions requirements (which are much less strict than new-car emissions requirements), and want as much power as possible while staying right on the edge of passing.
Bob Saveland
Former owner of #2517
