01-07-2008 | #1 |
Headers = resonance?
Title says it all. I had a Flowmaster cat-back and stock manifolds. Sounded great outside and quiet inside. Added headers and random tech cats, now it sounds incredible outside but I picked up a fair amount of resonance around 1800 rpm's. From everything that I ever read, I didn't think headers would make it resonate. Guess I was wrong. Corsa anyone?
1990 ZR1 #2574 Medium Quasar Blue Metallic 1 of 19 |
01-07-2008 | #2 | |
Re: Headers = resonance?
01-07-2008 | #3 |
SSW.
01-07-2008 | #4 |
I wonder if a set of corsas would mellow them out some? Your not running a resonator correct?
01-07-2008 | #5 |
The Flowmaster has a resonator built in. When the exhaust shop welded everything up they had to shorten the cats as well as the inlet pipes to the mufflers. I know I'm grasping at straws there but, the whole thing seems strange.
01-07-2008 | #6 | |
01-08-2008 | #7 |
i ahd a set of flowmasters on my black car with headers and no cats . once i adjusted the hangers (those spring things that hold up the exhaust ). mine were too loose and the muffler tips so that there was a min. of 12mm below rear opening the inside of the car got alot quieter. how i found out was the passenger muffler moved and got real close to the opening which made it very loud inside the car.hope this helps
01-08-2008 | #8 | |
There are no limit's mans ingenuity, just as mans ingenuity will never conquer the forces & behavior of this planet...Smokey Y. |
01-08-2008 | #9 |
I bought a set of Flowmaster mufflers and installed them in place of the stock '90 mufflers.
Resonated like a bad dog at highway speeds in 6th gear. The drone would drive you nuts. It also burbled and popped on deceleration (which I didn't mind). I put a complete Flowmaster setup on and the resonance and pop are pretty much gone. Next step will be x-pipe in place of the resonator later when the weather warms a little. Don't want to argue with the Smog Nazi's so no plans for headers or removing/replacing the cats in my near future.
01-08-2008 | #10 | |
