Old 12-17-2007   #1
va beach biker
va beach biker's Avatar
Default Performance clutch?
The car is most likely going to get a Fidanza flywheel this winter, it would seem like the time to put in a clutch as well. Any points as to a good choice - Centerforce, Carolina, etc?
1991 Red / Black
SLP Intake / Haibeck Chip / B&B Catback
va beach biker is offline   Reply With Quote
Old 12-29-2007   #2
Cdn ZR1 Mike
Cdn ZR1 Mike's Avatar
Default Re: Performance clutch?
No responses?? I'm in the same boat.....
1990 ZR1 Ported Intake, IH's and PC'd (JeffVette), 4:10's, SLP air intake, SW headers, X-pipe with flowmasters. Haibeck chip. 12.1 @117mph on GSD-3's. :mrgreen:
Cdn ZR1 Mike is offline   Reply With Quote
Old 12-29-2007   #3
Jagdpanzer
Jagdpanzer's Avatar
I've got a Fidanza flywheel going in this winter as well and I'm staying with the stock disk and pressure plate as it has only 7500 miles on it and it is working fine.
I thought about ungrading however, after reading Haibeck's comments on the issue http://www.zr1specialist.com/HAT%20W...eel-clutch.htm decided stick with what the General issued for now.
Old 12-29-2007   #4
tccrab
tccrab's Avatar
From what I've read over the years, the stock clutch is just fine for nearly all stock/mildly modded street applications.
Highly modified cars need more sticky and less civility for drag racing, so they generally opt for the aftermarket kevlar type clutches and they have to change them regularily.
If after reading Marc Haibec's write up you still have questions, contact Bill Boudreau, "The ZF Doc".
http://www.zfdoc.com/
TomC
'90ZR1 #792
Honorary Pirate
[/B]
Old 12-30-2007   #5
rkreigh
I'm running the stock clutch on the fidanza. with the LPE 390 and the 234 cams, the rattle is pretty loud, but with the B&B exh, you really don't hear it that much inside the car. I did notice that drag racing the car (508 rwhp) as marc mentioned I'm at the limit the stock clutch can take and it can get glazed pretty easily.
we also tried a mcleod sprung disk and had a rather dramatic failure, one side of the disk had about 1/3 of the material let go after one burnout.
I have to think that this was likely just a defective disk, as marc has used these disks quite a bit with good results.
when going to the fidanza, you should consider a sprung hub disk to help quiet things down. the stock disk is solid, and will be a bit noisier, although in my application, I honestly didn't notice any difference at all. it was loud before, and it's still loud!!
the fidanza is a good alternative, just be prepared for the gear rattle. having the chip updated for a bit higher idle speed helps, and also many zf boxes are quieter than others, the boxes that bill b blueprints seem to be quieter and shift better too!!
95 390 LPE ZR1 (505 rwhp)
Old 12-30-2007   #6
Jeffvette
If you are looking for a nice sprung disc, take a look at the McLeod 261871. It's a kevlar disc and is sprung.
But for all purposes, a stock clutch disc is fine. Dwight still runs one in his 415, although it did get a little hot at the BG drags from hot lapping it.
Old 12-31-2007   #7
RHanselman
RHanselman's Avatar
Jeff,
What would you recommend for 800 chp and above?
Cheers,
Ron
Ron Hanselman
Founding Member #80
CM Lifetime Member #1093
1991 #383 Twin Turbo
1993 #099 Ruby, Jeal 368 w/Snake Skinner body
1961 White with Red Int
RHanselman is offline   Reply With Quote
Old 12-31-2007   #8
Jagdpanzer
Jagdpanzer's Avatar
With a Fidanza al flywheel does the spring hub of the McLeod 261871 help reduce the gear rattle much?
Old 01-04-2008   #9
ZR1 MK
I use the Spec Stage 2 pressure plate and clutch with the Fidanza. Never tried other aftermarket stuff on this car, so I can only compare to stock. I like the results. You wont eliminate the slight rattle, but the springs help.
Mike
427 cu in LT5
[URL="http://zr1mk.weebly.com"]http://zr1mk.weebly.com[/URL]
ZR1 MK is offline   Reply With Quote
Old 01-05-2008   #10
Usa1-Zr1
Usa1-Zr1's Avatar
I have the same set-up as above in my Ruby with proper break-in it's doing great.
Ruby ZR-1 car #95 lots of bolt-ons never opened up 390- RWHP
Usa1-Zr1 is offline   Reply With Quote
