Old 09-29-2007   #1
va beach biker
va beach biker's Avatar
Default Bad amps?
Just to sanity check before I go ordering new parts, what are the symptoms of the amps going bad? Right now I have a constant, heavy, static noise coming from both the front speakers. It's present as soon as the power is turned on, and bad enough that you have to crank the volume just to hear anything.
1991 Red / Black
SLP Intake / Haibeck Chip / B&B Catback
va beach biker is offline   Reply With Quote
Old 09-29-2007   #2
Z Factor
Z Factor's Avatar
Default Re: Bad amps?
It could be a couple of things, but is most likely you amps going bad.
This thread from the audio section has a few places to consider.
http://zr1netregistry.com/forum/showthread.php?t=643
Old 10-05-2007   #3
Cdn ZR1 Mike
Cdn ZR1 Mike's Avatar
I used the amps out of a Nissan that had a BOSE system when my rear amps dies. I ended up swapping everything over including the new speakers etc and retained the ZR1 speaker/amp casing. Fit's like a glove. The speakers came out of a 2005 Pathfinder but almost any year should work provided it came with the BOSE system.
1990 ZR1 Ported Intake, IH's and PC'd (JeffVette), 4:10's, SLP air intake, SW headers, X-pipe with flowmasters. Haibeck chip. 12.1 @117mph on GSD-3's. :mrgreen:
Cdn ZR1 Mike is offline   Reply With Quote
Old 10-05-2007   #4
evl_twn
evl_twn's Avatar
Same Day Auto Audio
757-277-1080
And the best part, they are local to you in Chesapeake.
evl_twn is offline   Reply With Quote
Old 10-06-2007   #5
va beach biker
Chesapeake - good to know that. I was about to start boxing up stuff to send to Bose.
1991 Red / Black
Old 12-07-2007   #6
kengodfrey
My amps went out. I called Bose, they sent me 4 new ones, at $75.00 each, plus shipping. They did not want my old ones. I changed all 4 out in 3 hours. You can get instructions on this site. I bought instructions for $10, on the internet from a site mentioned in ZR1registry.
kengodfrey is offline   Reply With Quote
