Old 07-05-2022   #1
tokuzumi
Default I think I found the cylinder that is not running optimally
No SES light, but the car definitely wasn't running optimally in the low RPM range. Pulled the plugs on the driver's side. Cylinder 5 (assuming driver's side front to rear is 1/3/5/7) was coated in oil on the threads...no oil pooled in the socket.
Most of you probably know already, but the LS based engines use the same size plug as the LT5, so I swapped out that plug. Gap was significantly smaller than the others. Didn't appear to be mechanically gapped, so I don't think there was any piston contact.
Need to check the passenger plugs, and will use the rest of my NGKs to do a halfway tune up. I won't replace wires or coils for now.PXL_20220705_235729766.jpgIPC_2022-07-05.20.02.42.2530.jpg
Sent from my Pixel 3 using ZR-1 Net Registry mobile app
tokuzumi is offline   Reply With Quote
Old 07-05-2022   #2
Hib Halverson
Default Re: I think I found the cylinder that is not running optimally
That plug is badly oil fouled. I'm not sure about what I saw in the second image. By chance is that the piston top shot through a bore scope?
In any event, you may have a problem with a valve seal or a broken ring.
Hib Halverson
Technical Writer
former owner 95 VIN 0140
current owner 19 VIN 1878
Old 07-05-2022   #3
tokuzumi
Second picture is from an endoscope.
Old 07-05-2022   #4
tokuzumi
I'm hoping my issue is the former. But after Googling what causes the oil smoke (under hard acceleration), it is looking like the latter
Old 07-06-2022   #5
tokuzumi
Car runs smooth as glass now. Interesting how things run when all cylinders are firing.
Old 07-06-2022   #6
Wouldn't a compression test reveal if there is a broken ring? Why not try that. --Bob
Old 07-06-2022   #7
Bob,
Had a similar situation with my old block. Compression tested fine even though compression ring was cracked in 4 places from detonation due to a bad injector. However, I was getting oil smoke under acceleration.
Depending on which cylinder, ie 1/3 or 2/4, could be injector housing gasket allowing oil seepage from one of the oil windage ports.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 07-06-2022   #8
tokuzumi
Bob,
I'm assuming the cylinder numbers are like the small block Chevy so it was piston 5 (3rd from front driver side).
I can pull the plenum at a later time and get the injectors cleaned and flow tested to ensure proper operation. Slap some new o rings and see what happens.
But if I had to do some engine upgrades....
Old 07-06-2022   #9
If you are going to have injectors flow tested, then go thru the process of flow matching the injector pairs if needed. Some injectors may need to have harness locking tab removed to do this.
Old 07-06-2022   #10
tokuzumi
I'm in the Atlanta Georgia area, but could ship them somewhere.
Would it be best to ship to a company that knows the LT5, or would any reputable injector refurb place be up to the task?
