03-15-2020 | #1 |
Pilot bearing knocked out my engine plug
Help I have a 90 zr1 I was replacing the pilot bearing on and I knocked out the engine plug behind it. Any tips on how deep to set my new plug since I don't have a reference now. And tips or tricks to set it right. Thanks everyone.
03-15-2020 | #2 |
Re: Pilot bearing knocked out my engine plug
The search feature for this forum is your friend. It’s what makes the big difference between a forum like this and Facebook. The later being very difficult to search.
The following thread should help. Good luck and don’t worry, this stuff happens to all of us. H http://www.zr1.net/forum/showthread....ght=Crankshaft
03-15-2020 | #3 |
Thank you so much
03-15-2020 | #4 |
By "I knocked out the engine plug behind it" do you mean
pushed the rear engine seal into the engine? Can that happen? That would be no bueno.
1995 ZR-1 #106 Blk/ Blk Owned by me since 2000. 93K miles, but not on motor :-) Mods the way I want it, Not afraid to drive it! |
03-16-2020 | #5 |
Yes I popped the plug into the motor and need to install a new plug after I tear the entire clutch and flywheel out again. Ugh.
03-16-2020 | #6 | |
I'll camp on this one....
03-16-2020 | #7 |
No big deal. It drops into the oil pan and you put in a new one. I’m told it will be ok if I set the new one correctly. More worried about not screwing that up and what the best depth is to put it back in since I have no reference as to where it was originally. Ugh
03-16-2020 | #8 | |
[FONT=Comic Sans MS][COLOR=red]"I wanna go fast!!"[/COLOR][/FONT] [FONT=Comic Sans MS][COLOR=#ff0000]-- Ricky Bobby[/COLOR][/FONT] |
03-16-2020 | #9 |
It’s defiantly a miniature freeze plug. It’s behind the pilot bearing. Holds 12 quarts of oil in. Most frustrating mistake I ever made. Put it all back together to find out I punched it in by accident.
03-17-2020 | #10 | |
If it is pushed into the crank, it may restrict or block oil pressure to passages for main or rod bearing. Going off memory, which it's been 10 + years I had it apart, but I don't think it is possible for it to make it to the pan if pushed in. I hope you found it, or I'm wrong, because it could be hard to get out of the crank. But worse if a bearing starves for oil.
