Old 03-07-2020   #1
32ValveGuy
Default Oil Dipstick
Hey Guy’s,
Where do you put the bend on the dipstick to keep it from pushing upwards.
Thanks
[SIGPIC][/SIGPIC]1990 White/Red ZR-1 #1736
Bone Stock and staying that way (might cheat a little)
1959 MGA Twincam - sold
1967 Camaro SS 350 - stolen
1968 Camaro RS - traded in for a Vega - stupid
2002 Camaro SS SLP, rag top, last year haha - sold
32ValveGuy is offline   Reply With Quote
Old 03-09-2020   #2
secondchance
Default Re: Oil Dipstick
Originally Posted by 32ValveGuy View Post
Hey Guy’s,
Thanks
I am not so sure bending the dipstick would help. How far does it pop up? Mine, after daily driving, typically is about 1/4" above the top of the tube. This, of course, is due to crank case pressure.
secondchance is online now   Reply With Quote
Old 03-09-2020   #3
32ValveGuy
It rises about 1/2” above the tube. Is this normal?
Old 03-09-2020   #4
EvanZR1
EvanZR1's Avatar
It's really more about proper venting of the engine due to crank case pressure at high rpm. I was getting constant dipstick "push up" after getting the car back from Pete with the 391 with stage 2 cams (shift light set at 7300rpm). Steve @ Crossed Flags installed a Mighty Mouse catch can I had bought as well as fixing some cam cover vent tube/hoses as well as the PCV valve/hose. Since doing that, it's pretty well fixed the issue.
Evan
2024 Z06
SOLD - 1991 Admiral Blue ZR-1
SOLD - 2012 Carlisle Blue Metallic ZR1 - 800HP
SOLD - Steel Blue 91 391cid ZR-1 #391
SOLD - Black 91 ZR-1
EvanZR1 is offline   Reply With Quote
Old 03-09-2020   #5
secondchance
How many miles on the odometer? 1/2” is not truly abnormal depending on the mileage.
I would clean both PCV valves. Might help.
Old 03-09-2020   #6
32ValveGuy
It has 40k miles on it and I just clean the pvc valves and used new hoses when I replaced the injectors
Old 03-09-2020   #7
secondchance
I wouldn’t worry about it. I had mine completely rebuilt with 4” iron liners about 20,000 miles ago, running a catch can and the dip stick pushes up about 1/4”.
Old 03-12-2020   #8
Marc Haibeck
I find that about 7 out of 10 stock engines have the dipstick popped up about 1/2". This is not good because the PCV system can pull road dust through the leak.
The dip stick is probably loose in the tube. Years ago the dipstick had some friction from the rubber seal in the cap. By now the seal is as hard as solid plastic. To add some friction bend the flat strip just under the cap by about 45 degrees. Test to see if the stick gets stuck when you try to lift it. If not bend it a little more.
Old 03-12-2020   #9
secondchance
So, bending the stick would help and keeping the dust out is a good idea.
Learn something new even after owning ZR-1s for almost 29 years!
Thanks Marc!
Old 03-28-2020   #10
SAM/CH ZR-1
When we talk about oil dipstick. In some cases after years the T-Handle break. Does anybody know where a new dipstick can be purchased or is a aftermarket solution required?
Sam
DR.Z/LT5-Performance
1990 #1822 with 383 cui
SAM/CH ZR-1 is offline   Reply With Quote
