Old 08-13-2019   #1
Jetjock
Jetjock's Avatar
Default Hi Beam switch won’t work
When I got my car, I couldn’t get the hi beam switch to work. Gordon looked at it and got it to work temporarily but then it went back to not working. I managed to get it work but I need a permanent solution. I get the feeling that the rod moves around because something is missing. Any ideas?
Roy L. Carman
If I feel the need for speed,
I just think about flying the B-777.
1989 Dk Blue Coupe lost in divorce
1991 Black Coupe SOLD
1992 Black ZR-1 #423 SOLD!
1993 Ruby Red 40th Anniversary ZR-1 #334
1995 Black ZR-1 taken by ex-wife
2002 Pewter Coupe no idea where it is
2003 50th Anniversary Corvette #No idea what number SOLD!
ZR-1 Net Registry #516
Grand Sport Lifetime Member
NCM Lifetime #1468
ZR-1 Net Registry Board Secretary
Jetjock is offline   Reply With Quote
Old 08-13-2019   #2
Demps
Demps's Avatar
Default Re: Hi Beam switch won’t work
This is a crazy design. The dimmer stalk (blinker) is pulled which in turn pushes/compresses a semi-pliable rod running down the steering column that in turn pushes a toggle switch at the base of the column.
Sucky part #1: remove drivers kick panel & support backing. Find the rod & push down with your hand at the switch to engage the toggle dim—bright switch with your headlights on. Does the dim—bright toggle? Yes, the rod most likely has deformed in the middle where it bends around the mounting bracket. No, switch or another relay is bad (I undid something that disables the toggle...it’s in the service manual).
Sucky part #2: getting to where you can straighten rod. Lesson learned: it’s tricky to straighten it & keep it clear of bracket. Maybe fabricate something to slip on the end of the rod.
Ted
Old 08-14-2019   #3
Jetjock
Jetjock's Avatar
The dimmer switch works so it must be the rod. It works a couple of times and then locks up.
Roy L. Carman
NCM Lifetime #1468
Old 08-15-2019   #4
DRM500RUBYZR-1
DRM500RUBYZR-1's Avatar
It's the rod!
My techs would order a new handle and switch, then be frustrated that it still did not work.
Now, we go right to the rod.
No easy way, just takes time.
But almost 9 out of 10 it is the rod.
The 10 would be when someone breaks the stalk off.
Marty
DRM500RUBYZR-1 is online now   Reply With Quote
