Old 07-24-2017   #1
onetinsoldier
Default ZR1 wheels ?
I recently found some A-mold style front wheels , the person said they were ZR1 wheels . I am not sure ,if you put the stem at 3 o'clock , theyre are two raised bumps at 12 and 6 on the face of the rim .The back of one spoke is stamped 17x8-1/2x56 . Are these oem ?
onetinsoldier is offline   Reply With Quote
Old 07-24-2017   #2
tf95ZR1
tf95ZR1's Avatar
Default Re: ZR1 wheels ?
I'm not sure if you are asking if the rims are
OEM or ZR-1 specific.
For OEM check:
http://www.zr1.net/forum/showthread....ht=oem+a-molds
stamped on the inside
For ZR-1 specific you need to check the offset.
ZR-1 offset is unique
As for the "bumps" I wonder if they are to balance the rim?
IMHO, no bueno.
Old 07-24-2017   #3
onetinsoldier
OEM ?
Old 07-24-2017   #4
tf95ZR1
tf95ZR1's Avatar
Original Equipment Manufacturer (OEM)
vrs aftermarket
The other issue is offset.
Will the tires be flush with the fender or
stick out or sit tucked inside?
Old 07-24-2017   #5
Ronstar
if they are 17x8.5 they are not zr-1 rims
Ronstar is offline   Reply With Quote
Old 07-24-2017   #6
Those are not OEM. If they were they would have a JWL stamp on the face of the wheel, a GM part number on the rear of the wheel and a made in JPN stamp. 17 x 8.5 OEM A molds were on collector editions but never a ZR-1
Sent from my iPad using ZR-1 Net Registry
Old 07-24-2017   #7
onetinsoldier
ok............ They are 1996 collector Z51 rims ! And probably an aftermarket type.
Old 07-24-2017   #8
WVZR-1
NO - they show no signs of being GM what so ever!
With the valve stem @ 6:00 a GM/OE wheel will display a JWL in the argent of the 2nd window 'clockwise' of the valve stem.
This 2011 thread on the CF has a very good image of a GM 5-spoke wheel. Notice 2d window clockwise from valve stem. Regardless of width a GM/OE will display that JWL. There's a 9" wheel that was used on Camaro cars that had a GM cast into it.
https://www.corvetteforum.com/forums...-for-sale.html
Old 07-24-2017   #9
Not the wheels the have pictured
