Old 07-06-2015   #1
secondchance
Default Electrical connector question
This is one of two connectors for the HVAC fan speed controller (fan resistor). Has anyone been successful in removing pins out of the plastic connector? Hold down clip is broken off and I found a replacement connector but if possible I would prefer to relocate existing pins as opposed to splicing the wires.
Old 07-06-2015   #2
WVZR-1
Default Re: Electrical connector question
That's a Metri-Pack 480 and here's enough information to get you through un-pining it. You don't need a specific release tool, just something that's very similar. Your connector should be 3 populated and 1 plugged I'm quite sure.
http://catalog.delphi.com/connectors...ure/met480.pdf
Cross-Sectional view is a "tell-all".
If you've bought a 4 pin connector and would like a correct cavity plug let me know.
Old 07-06-2015   #3
secondchance
Hey Dave,
Thanks. Just what I needed. I bought a used controller and it's being sold with both connectors with cut wires.
Old 07-08-2015   #4
secondchance
Thank you David. Successfully repinned.
Old 07-09-2015   #5
WVZR-1
Good to hear all went well. See you "next month"!
