Old 07-31-2014   #1
QB93Z
QB93Z's Avatar
Default WTB - I need the door glass guide (C4)
I need the door glass guide for passenger side glass.
This guide (a plastic piece) attaches to the lower, forward corner of the glass and rides on the guide bar to position the glass properly as it is raised.
My guide is broken and the glass goes too far up and then the upper rear corner of the glass hits the edge of the halo when the door is closed.
I believe that the part I need is not year specific, and it is not ZR-1 only.
Anybody got one?
1990 Black ZR-1 - sold
1993 Quasar Blue ZR-1
1994 Competition Yellow ZR-1
1995 Dark Purple ZR-1
Maryland State Coordinator
Old 07-31-2014   #2
Jagdpanzer
Jagdpanzer's Avatar
Default Re: WTB - I need the door glass guide (C4)
Jim,
I just did this repair on my driver side window.
Found the the guide on ebay.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 07-31-2014   #3
Jagdpanzer
Jagdpanzer's Avatar
Here you go
Right side:
http://www.ebay.com/itm/1992-thru-19...#ht_2736wt_868
Left side:
http://www.ebay.com/itm/1992-thru-19...#ht_2893wt_868
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 07-31-2014   #4
QB93Z
QB93Z's Avatar
Thanks Phil. I thought it was too obscure a part for eBay. Silly me.
Bought it!!
Old 07-31-2014   #5
Fully Vetted
Fully Vetted's Avatar
Jim, I just did this repair as well. You're going to have fun with the nut that holds that stop/guide on. The back side is basically a big washer with 2 opposing holes and you have to either buy the tool ($65) or improvise. I used a set of 90 degree needle nose pliers. It is very tight and has thread locker on it. That was the most difficult part of the install. The only difficult part actually.
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
BBC - Bling By Carter:
Old 08-01-2014   #6
Does anybody know if these will work on a 90 or 91? I know it was an improvement for all MY92s and up because of the rattle glass problems in 90and 91 when the windows are down. Anybody has this mod or done this yet? I dont think so im not sure if the 90s and 91s have the rod guide that holds this stop in the window, nor the hole in the window where the guide stop goes? Phil ??/ Anybody please advise -=JEFF=- ?
Note to JIM I think I have this specific socket with the two tines on it. LMK if you like to borrow it? Also Jim great pics below of the work details.
GC
http://forums.corvetteforum.com/c4-t...indow-fix.html
Old 08-01-2014   #7
WVZR-1
The parts are still available at the dealer and if you've a relationship with a dealer you should be able to buy them competitively priced.
The parts were added in MY '93 I believe and the glass was updated at the same time. These would not work in '90 cars as the glass isn't the same as later cars. "91 & '92 if the glass is original I don't believe the hole is present unless the glass has been replaced and then it's likely.
The parts mentioned are '93 thru end of production.
That is a 'spanner' socket and if yours has the round projections that are direct fit to the spanner nut that would be fine but *I don't believe the guide uses the spanner nut. The 'spanner' socket is generally pretty easily manufactured using the appropriate old socket and a grinder/dremel to modify it.
* I found a couple references to the 'spanner' so it's likely used. I've never had a later door apart.
Old 08-01-2014   #8
I believe it uses a spanner nut as can be seen in the mirror in the corvette forum link I provided in my post. Good info thanks.
Has anybody done this conversion yet with an earlier model car? GC
Old 08-01-2014   #9
WVZR-1
I see a couple revisions on the glass BUT they're all 4 hole glass so if a person had the guide channels and the stops I would think they could be maybe added to the '91 or 92. I can't find any visual images of the '91+ door glass. I can find many for the '84 - '90 and again it's a 4 hole glass but is the forward most hole in the same location? If it were then the add to a '90 could be possible but you need to be able to cannibalize '93+ doors for the guide channels. There are left and right with no availability from GM.
If someone has a '93+ door on the ground they could remove the glass and I believe comparisons by snapshots might answer the question: Can these be added?
Old 08-01-2014   #10
Jim here is a picture of the tool. Which basically is a special socket. Lmk GC
