03-20-2014 | #1 |
Offset Ground Crank
For those who have done motor upgrades utilizing an offset ground crank....how did you flush the oil gallery in the crank? Should all the plugs be removed from the crank to do a proper flushing?
Rich
03-20-2014 | #2 |
Re: Offset Ground Crank
Yes remove all the plugs. Whatever you do make sure the Crank expansion plug are welded when you put it back together.
