![]() Join Date: Nov 2013
![]() ![]() What's the torque value in the FSM that he says is incorrect??? |
![]() Join Date: Feb 2011
I have a 95 FSM book set that was printed in Dec of 1994 and has the correct torque value of 70 lb/ft shown. The front abutment bracket has a much much higher toque- like 160 lb/ft or something.
My FSM on page 5B2-6 says 166 +/- 15 lb.ft. This is the rear brake section but matches word for word the front brake caliper mounting bolt wording. Mine is also printed Dec 1994.
#5 | |
The clue being that it says (verbatim from the front brake procedure) to tighten the 'two front caliper mounting bolts'. Brakes are so straight forward, I never would have read that anyhow- just go to the last page for the torques and that's that. |
Well I'll be doing this very shortly w C6Z06 rear calipers. Need to check if the torque spec is the same. My 1/2" torque wrench only goes to 150lbs.
