12-22-2013 | #1 |
Winter Storage
Time to put the Z away until all the salt's off the streets so need a few recommendations. What brand of fuel stabilizer (if any) do people use and what tire pressure should I inflate to avoid "flat spots" (I have Goodyear F1 Eagles). I plan on firing it up every 2-3 weeks to get it warm and move around in garage to help prevent flat spots.
Thanks, in advance, for advice! Tom |
12-22-2013 | #2 |
Re: Winter Storage
Sea Foam is the one I use for my gas. Great stuff. Make sure to fill the tank all the way so no rust sets up on your fuel pump.
http://youtu.be/f5faqSGWSlo I start mine every month and run for 10-15 min. I also push on the brakes several times each month during warm up. I leave my tires at regular PSI and in the spring after the first few miles they are good to go for the season. I have Dunlop brand. After a few good applications to the brakes the rust burns off and are good to go. This has been my routine for many years now.
http://i119.photobucket.com/albums/o...9mcw/SIG-2.jpg http://i119.photobucket.com/albums/o128/wb9mcw/vcm.gif "The Budget should be balanced, the Treasury should be refilled, public debt should be reduced, the arrogance of officialdom should be tempered and controlled, and the assistance to foreign lands should be curtailed, lest Rome will become bankrupt. People must again learn to work instead of living on public assistance." - Cicero, 55 BC " We the people are the rightful masters of both Congress and the courts, not to overthrow the Constitution but to overthrow the men who pervert the Constitution." - Abraham Lincoln Last edited by WB9MCW; 12-22-2013 at 06:39 PM. |
12-22-2013 | #3 | |
Re: Winter Storage
Winter Storage Winter Storage TIPS
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 12-22-2013 at 06:17 PM. |
12-22-2013 | #4 |
Re: Winter Storage
Thanks for the recommendations!
Tom |
12-22-2013 | #5 |
Re: Winter Storage
12-23-2013 | #6 |
Re: Winter Storage
I have raised my tire pressure to 60 psi while the car is stored on the rack. We have a local specialty car restorer and seller here named Tom Snellback who runs the Last Detail. He stores about 100 or more exotic cars including a bunch of Michael Jordan's. He says his routine for storage is fill the gas tank, disconnect the battery (and keep it on a float charger) and 60 psi in the tires. I have do the same although I leave the battery in the car. The tires look surprisingly round as they sit on a very small contact patch. --Bob
2016 Long Beach Red Z06 #10281 "POPS Z" 1995 Polo Green #409 "WARP TEN"--Haibeck 350/510 package, 4.10s, Hurst, Stock Exhaust with QTP Cutouts --Sold but still running strong 1993 Quasar Blue #161 "HIL KING" --Sold but still running strong, now with more than 120,000 miles 1967 Marlboro Maroon/Saddle Corvette Coupe 300 hp/4-spd --Sold a long time ago ZR-1 Net Registry Founding Member #95 NCM Lifetime Member Favorite Quote--Attributed to Mickey Thompson: "Too Much Horsepower is Almost Enough" Last edited by WARP TEN; 12-23-2013 at 04:34 PM. |
12-24-2013 | #7 |
Re: Winter Storage
12-24-2013 | #8 | |
Re: Winter Storage
I was assuming Tom Snellback stores all exotic cars on concrete inside storage.
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 12-24-2013 at 06:42 PM. |
12-26-2013 | #9 |
Re: Winter Storage
On the ground is the same. I just happen to have a lift on which I store the Z; park the other car underneath (pix in my albums section). If I take it down for a drive I will adjust the pressure to 35. You could certainly use some sort of tire cradles as well, but I don't. -Bob
12-26-2013 | #10 |
Re: Winter Storage
The tires are still on a surface bearing weight, on racks. You do not want to store a car for long with the suspension fully extended, no one does that.
The ideal would be to pull the wheels and have car sitting on blocks with suspension taking car weight. Esp with and sort of performance rubber. Even with 60 psi, the rubber witself will still flatspot.
peace Paul ZR-1 Net Registry Member #1494 |
