![]() Join Date: Sep 2013
As I understand it there are two build sheets buried in the chassis: 1 between the gas tank/the body and 1 somewhere in the pass side frame rail.
Am I correct? is the frame rail one easy to get to with out major disassembly? thx |
![]() Join Date: Oct 2004
The ones I've seen in the front are in the cross-member and would be difficult to recover. It's certainly I believe a more "practical" purchase from the NCM. It will also be legible!
![]() Join Date: Apr 2007
Second that! I got both my build sheet and my window sticker, including a laminated one for car shows. At some point I will retrieve the build sheet from the tank (which on my 93 Z was accessable through the license plate bracket), but for now I am fine with the NCM's items. --Bob
![]() Join Date: Apr 2004
I guess I was lucky got 2 original window stickers with my car, I bought it from the original owner with 9K miles on it in 2002.
Thx everyone. I did get a set from the museum. just felt like tinkering on the car this weekend and if they were easy to get to would try and retrieve.
can I get to the gas tank one via the license plate area like you mentioned on your 93? thx everyone |
It has been quite a few years but as I recall I removed the wide license plate bracket and was able to see the top of the tank. I could see the build sheet so I just reached in a carefully worked it free. Came off complete and in good shape. Anyone else do this? Am I recalling it correctly? --Bob
