Old 08-12-2006   #1
Peaven
Peaven's Avatar
Default Iridium plug gapping
Just picked up a set of TR55IX plugs....NGK has them gapped at .059 and says to leave them there...LT5 specs of course say .050, so....which one is right?
Anybody that has theses plugs got any insight....Uly?
Thanks for the help gang.
SteveB
'94 ABZ Lucky #13-SOLD
Peaven is offline   Reply With Quote
Old 08-13-2006   #2
blackjack
Default Re: Iridium plug gapping
im sure the ngk big boss doesnt know what a zr-1 is....the gm service manual says .035...the wider the gap,the harder it is for the coil to fire the plug,to the point of misfire,specially the newer plugs with so-called precious metal,which is good for long life,buut not so good for conductivity...i gap my ngk at .040,no mo'
blackjack
91/1735
Old 08-13-2006   #3
guinnessdood
guinnessdood's Avatar
I have the same plugs but cannot remember for the life of me the correct gap. Call Corey Henderson and he will tell you... 210-867-6286. If you are running the stock coils and the original or stock wires I would gap them at no more than .045. If you have better wires and/or coild you could go out to .055-.060....so my research tells me...
Uly
Past OWNER 90 ZR-1 #0120 Red/Saddle
UT Plate: EZR1DER
guinnessdood is offline   Reply With Quote
Old 08-14-2006   #4
Peaven
Peaven's Avatar
Thanks guys ....I think the 90-92 LT5's spec gap is .035 but the 93-95's get the gap spec'd at .050, no?
I'll either call Corey or Marc Haibeck tomorrow, thanks for the phone# Uly.
SteveB
