02-27-2013 | #1 |
Rear wheel HP estimate
Greetings from Moscow! Quick question - realistically how much rwhp can I expect with ported heads/IH and Pete's cams. Also, what trap speeds and mph are ya'll running in the 1/4? Once i get back from my biz trip, I'll be taking my car to Corey so he can work his magic!
[B][U]---SOLD BUT NOT FORGOTTEN---[/U][/B] [SIZE="1"][SIZE="2"]1992 ZR-1 #483 [COLOR="DarkRed"]Dark Red Metallic[/COLOR] [U][B]Mods[/B][/U] -Jeal headers -Stock exhaust with X-pipe -4.30 Gears -Corey Henderson tune -375 RWHP[/SIZE][/SIZE] |
02-27-2013 | #2 |
Re: Rear wheel HP estimate
420-440rwhp; traps at 120-125, depending on how good a driver you are and tires you use
02-27-2013 | #3 |
The Automasters "Street Skinner" engine in my 95 made 413 SAE-corrected at the wheels on a DynoJet with stock manifolds and cats.
If you add headers and cams to a 350 with head/housings/plenum work and cams I'd hope for at least 430 at the wheels. Anything less and I'd want my money back. I'd say your speed in the quarter will be 120-130. As for the e.t? That will depend on your driving talent, axle ratio, rear tires and your suspension set-up.
02-28-2013 | #4 |
I've got right at 420 to the wheels without cams. Pete did the port work and the SW headers. Have not been to a track.
02-28-2013 | #5 |
420 at the wheels..SAE-corrected or standard-corrected?
03-01-2013 | #6 |
Good question. Corey did the pull last month. I'll be picking the car up here pretty quick. I'll ask.
03-01-2013 | #7 |
When i dyno'd that Z it made 425 SAE Corrected
I heard Corey got 428 out of it. I think 430+ should be possible from that Z but then again every Dyno is different 420-430 is withen tolerance Some shops have unfriendly dyno #'s till you drop some cash then they get you some friendly dyno #'s. This is why i always dyno'd at two different Dyno's just to compare. Look up Dynojet tricks how they can play with Dyno #'s What i have discovered at my 600ft elavation track and my Z with stock front wheel/tires. 370-380rwhp 115-117 1/4 MPH 390-410rwhp 117-119 1/4 MPH 415-430rwhp 119-121 1/4 MPH 435-450rwhp 121-123 1/4 MPH 465-475rwhp 128-129 1/4 MPH aluminum pullies half weight over stock saves 2.5lbs,ATI balancer minus 2lbs,flywheel/clutch set up saved a bunch (200lbs overall total) Pete
'91 #1635 PoloGreen 350 LT5 11.09 @ 129.27 11.04 @ 128.86 474RWHP 400RWTQ http://www.youtube.com/watch?v=SFNFOhGGlR4 http://www.youtube.com/watch?v=ZlRIOMwaDYY https://sites.google.com/site/peteszr1garage Last edited by Pete; 03-01-2013 at 02:20 AM. |
03-01-2013 | #8 |
Pete,
You've got the last 25 rwhp making a 5+ MPH trap speed?
03-01-2013 | #9 |
Since then i re-ported my plenum/IH's a bit bigger i also mention i reduced rotational weight between pullies,ATI balancer,clutch/flywheel i'd say 25lbs maybe more and about 200lbs dead weight.
Pete
'91 #1635 PoloGreen 350 LT5 11.09 @ 129.27 11.04 @ 128.86 474RWHP 400RWTQ http://www.youtube.com/watch?v=SFNFOhGGlR4 http://www.youtube.com/watch?v=ZlRIOMwaDYY https://sites.google.com/site/peteszr1garage Last edited by Pete; 03-01-2013 at 03:13 AM. |
03-01-2013 | #10 |
Wow how'd you reduce 200lbs? Inquiring minds wanna know
