Old 01-30-2013   #1
Default helmets?
The 1/2 mile shootout requires a DOT approved helmet, purchased in the past ten years. I have one I've had for a little longer - paid over $100 @ the time, but what difference does it make when I bought it? Any full face shields that are favorites out there? Any to stay away from?
TIA,
P.
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 01-30-2013   #2
Jagdpanzer
Jagdpanzer's Avatar
Default Re: helmets?
Can't go wrong with a good Bell or Simpson helmet Snell SA2010 rated
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 01-30-2013   #3
PhillipsLT5
PhillipsLT5's Avatar
I would go with full face Simpson
Its your safety
snell 2010 good
Try this
http://www.summitracing.com/search/p...series-helmets
Old 01-31-2013   #4
The 1/2 mile shootout requires a DOT approved helmet, purchased in the past ten years. I have one I've had for a little longer - paid over $100 @ the time, but what difference does it make when I bought it? Any full face shields that are favorites out there? Any to stay away from? TIA, P.
I need to get one also. SA2010. There are some inexpensive ones that are SA2010 aproved, like G Force. My issue is I want to try a couple on to verify size, fit, vision etc. and it is hard to find a place close by to do so. I have spotted one retailer in Barrington, Northstar Motorsports that sells helmets and one day soon I will head over there. Anyone aropund Chicago know of anything closer to Lake Bluff IL? Plenty of Harley delaerships around but they say motorcycle helmets rated SA2010 are not acceptable, although I don't know why. --Bob
Old 01-31-2013   #5
Jagdpanzer
Jagdpanzer's Avatar
Here is a link to Snell Standards site
http://www.smf.org/stds
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 01-31-2013   #6
Thanks so far all..
Yeah, Bob, same here. I have a rated motorcycle helmet, & I guess it doesn't qualify. I don't know how close they check, but I'd rather not be kept from racing for lack of a "brain bucket" that I should have anyway. There is a polaris joint nearby, and maybe they have some I can try on, at least to get the size right.
P.
90 #1202
Sans secondaries
Old 01-31-2013   #7
gbrtng
gbrtng's Avatar
Motorcyclists use M-rated helmets - SA-rated ones are flame retardant which
apparently does not interest bikers. No reason why you can't ride your Harley with an SA helmet.
Old 01-31-2013   #8
Ronstar
What else is required besides a helmet?
Ronstar is offline   Reply With Quote
Old 01-31-2013   #9
batchman
IIRC Snell ratings are much more stringent than DOT. Pretty sure a Snell M helmet meets DOT.
Helmets age out due to reliance on foam, which degrades with time.
Sounds like a blast - looking forward to your post on topic.
Best,
- Jeff
[/I]
Old 01-31-2013   #10
cvette98pacecar
This is the Cheapest that I found. The Bandit is roughly 150.00 cheaper than everyone else.
http://www.amazon.com/Simpson-420003...im_sbs_auto_12
Robert J. DeMarco
[SIGPIC][/SIGPIC]
NCM Lifetime Member #2655
Pacecar Registry Member
1991 Shinoda Aerobody Spyder,
1998 Pace Car
