12-20-2012 | #1 |
INF Reset
I will tackle this code over the weekend. I have a Tech 1 which I have never used. Can someone tell me what cartdrige and how to use this to find the fault code the reset it with the Tech 1.
Erv Myers 1990 ZR1 #1964 |
12-21-2012 | #2 | |
Re: INF Reset
Bulletin 90-436-9J - the bulletin I believe in it's entirety should be in the "Members only" section. I've not looked there recently but I would expect it's there. 1991 Body Systems Cartridge (TKO4040A) and 1990 Dual UART/SIR Adapter (TA00065). The 1991 Body Systems Cartridge must be used because the 1990 Body Systems Cartridge has no SIR code-clearing capabilities for the 1990 Corvette. I am NOT sure if a "mass storage cartridge" will do '90MY SIR with the correct adapter. I've never tried but it is likely! The MSC wasn't available at the time of the TSB or at least I don't recall it being available in '91. Last edited by WVZR-1; 12-21-2012 at 08:45 AM. |
12-21-2012 | #3 |
Re: INF Reset
This might be useful. There is another one with a writeup and pics that I can't seem to find right now.
http://www.zr1netregistry.com/Inform...EST-light.aspx This is how to clear the codes right out of the FSM Just practice the cadence looking at the second hand of a clock a few times before trying on the car. Works great. 1. Turn ignition switch "OFF". 2. Ground ALDL terminal "K". 3. Turn ignition switch "ON". 4. Wait for fault codes to begin flashing (~5 sec). When the codes begin flashing, unground ALDL terminal "K" for 3 sec +/- 0.5 sec. 5. After ungrounding ALDL terminal "K" as described above, ground it again for 3 sec +/- 0.5 sec. 6. Unground ALDL terminal "K" and wait 10 secs. Before turning ignition "OFF", verify that Code 12 is the only code being flashed.
Scott Vett owner since 1979._It's about the car and the people Last edited by scottfab; 04-04-2014 at 12:03 AM. |
12-21-2012 | #4 |
Re: INF Reset
The '90MY TSB's won't open on the "Registry Members" TSB List and there's not a direct link to it either so here's the TSB I believe complete:
1990: Service Bulletin: SIR Diagnostics and Procedures to Prevent Codes 16 and 26 Due to Corrosion Subject: SERVICE MAN. UPDATE SEC.9J A/B REV. SIR DIAGNOSTIC PROCEDURE Model and Year: 1990 CORVETTE Source: Chevrolet Service Bulletin Bulletin Number: 90-436-9J - (11/07/1991) Some 1990 Corvettes have set SIR Sensor Codes 16 and 26. The DERM has detected an unacceptably high resistance between the SIR sensor and the frame rail, most likely due to a buildup of corrosion on the mounting surfaces. New service procedures have been developed to remove the corrosion and help prevent it from building up again. Removal and installation procedures, revised to address the corrosion issue, are attached. Please use these new procedures for all 1990 Corvette SIR Code 16 and Code 26 situations. IMPORTANT! - The corrosion condition and repair procedures apply only to 1990 Corvette; 1991 and subsequent vehicles do not set sensor codes due to this condition. The new procedures require the use of a special grease (P/N 12345579) and two external-tooth lock washers (P/N 11501869 - 8 mm, P/N 121753 - 6 mm) for the sensor mounting bolts. Along with the new procedures, please remember the following: 1. The "SIR Diagnostic System Check" in Section 9J-A must be the starting point of any SIR diagnostics. The "SIR Diagnostic System Check" will verify proper "INFL REST" warning lamp operation and will lead you to the correct chart to diagnose any SIR faults. Bypassing these procedures may result in extended diagnostic time, incorrect diagnosis, and incorrect parts replacement. 2. If both Code 15 and 16 (or 25 and 26) are set, use the Code 16(26) diagnosis chart first. Then, if Code 15(25) resets after the Code 16(26) is corrected, perform the Code 15(25) diagnosis. 3. To clear 1990 Corvette SIR codes, use the Tech 1 (part number T1 or 94-00101-A) with the 1991 Body Systems Cartridge (TKO4040A) and 1990 Dual UART/SIR Adapter (TA00065). The 1991 Body Systems Cartridge must be used because the 1990 Body Systems Cartridge has no SIR code-clearing capabilities for the 1990 Corvette. If the Tech 1, cartridge, and adapter are not available, codes can be cleared by grounding Terminal "K" of the ALDL connector as called out below under "ALDL Code-Clearing Technique". If using the ALDL procedure, be sure to follow it completely and exactly; codes can be difficult to clear using this method if the procedure is not carefully followed. 4. If the ignition is turned "ON" while any part of the 199O Corvette SIR system is disconnected, a code will set and remain set, even if the component is reconnected, until cleared by the technician. ALDL CODE-CLEARING TECHNIQUE When using this code-clearing technique, a digital wristwatch can be quite helpful. The timing sequence discussed below is very important to successfully clearing codes. The watch can help you with timing the 3-second intervals more exactly. 1.Turn ignition "OFF". 2. Ground ALDL terminal "K". 3. Turn ignition "ON". Do not start the car however. 4. Wait for codes to begin flashing (approximately 5 seconds). When codes begin flashing, unground ALDL terminal "K" for 3 seconds +/- 1/2 second. 5. After ungrounding terminal "K" as described in Step 4, ground it again for 3 seconds +/- 1/2 second. 6. Unground ALDL terminal "K", and wait 10 seconds. Before turning ignition "OFF", ground terminal "K" again and verify that Code 12 flashes six (6) times. If Code 12 does not flash six (6) times, codes have not been cleared properly. Begin clearing procedure again starting with Step 1. CODE 16 FRONT SENSOR #1 (LH) (SENSOR FAULT) Circuit Description: In a frontal crash of sufficient force, the Front Discriminating Sensor Switch closes, providing a path to ground for the deployment loop current. The sensor contains additional circuitry, used by the DERM for diagnostics. If the DERM measures more than a certain resistance value between the redundant ground circuit and the DERM's own ground, Code 16 will set. This code will also set if the DERM measures less than a certain resistance between the sensor feed circuit and B + or the diagnostic return circuit and B +. Severe corrosion under the sensor mounting bracket may cause a Code 16. Refer to "Left Sensor" on attached pages to remove sensor, inspect for corrosion, and correct corrosion if found. "Left Sensor" also instructs on use of special grease and washers to help prevent recurrence of Code 16 due to corrosion. The Fasten Seat Belt indicator will stay "ON" continuously when an SIR code has been set. If power is applied to the SIR system while any component is not properly connected, an additional code will be set for the disconnected SIR component. CODE 26 FRONT SENSOR #2 (RH) (SENSOR FAULT) Circuit Description: In a frontal crash of sufficient force, the Front Discriminating Sensor switch closes, providing a path to ground for the deployment loop current. The sensor contains additional circuitry, used by the DERM for diagnostics. If the DERM measures more than a certain resistance value between the redundant ground circuit and the DERM's own ground, Code 26 will set. This code will also set if the DERM measures less than a certain resistance between the sensor feed circuit and B + or the diagnostic return circuit and B +. If a Code 26 has set, a Code 25 may also be set. Severe corrosion under the sensor mounting bracket may cause a Code 26. Refer to "Right Sensor" to remove sensor, inspect for corrosion, and correct corrosion if found. "Right Sensor" also instructs on use of special grease and washers to help prevent recurrence of Code 26 due to corrosion. The Fasten Seat Belt indicator will stay "ON" continuously when an SIR code has been set. If power is applied to the SIR system while any component is not properly connected, an additional code will be set for the disconnected SIR component. FORWARD DISCRIMINATING SENSORS Caution should be used to assure proper location of sensors to the front frame rails. The keying of the sensors to the frame rails through the differently sized mounting bolt holes in the sensor mounting plate should never be modified in the field. CAUTION: Be very careful when handling a sensor. Never strike or jar a sensor. If you do, it could cause deployment and result in personal injury or improper operation of the Supplemental Inflatable Restraint (SIR) system. All sensor mounting bolts must be carefully torqued to assure proper sensor operation. Never power up the SIR system when any sensor is not rigidly attached to the vehicle, since the sensor is easily activated when not attached and could result in a deployment. LEFT SENSOR CAUTION: The following procedures must be followed in the order listed to temporarily disable the Supplemental Inflatable Restraint (SIR) system and prevent false diagnostic codes from setting. Failure to follow this procedure could result in possible air bag deployment, personal injury, or unneeded SIR system repairs. Remove or Disconnect 1. Turn ignition switch "OFF." 2. Left sound insulator; refer to INSTRUMENT PANEL, GAGES, & CONSOLE (SECTION 8C). 3. Connector Position Assurance (CPA) and yellow two-way SIR connector at base of steering column. 4. Battery; refer to BATTERY (SECTION 6D1). 5. ECM and support; refer to DRIVEABILITY AND EMISSIONS 9SECTION 6E3). 6. Sensor mounting bolts. 7. Sensor electrical connection from retainer; disconnect connection. 8. Sensor from vehicle. IMPORTANT Clean Sensor mounting bracket surface, frame rail mounting surface, and mounting bolts and holes to remove any paint or corrosion that might interfere with a good electrical ground. CAUTION Proper operation of the sensors and Supplemental inflatable Restraint (SIR) system requires that repairs to the vehicle structure return it to its original production configuration. Deployment requires, at a minimum, replacement of the DERM, both forward discriminating sensors, the SIR Coil Assembly, and the Inflator Module. Any visible damage to the sensors, DERM, and/or the DERM mounting brackets requires replacement, and the steering wheel must be dimensionally inspected, whether deployment occurred or not. Install or Connect 1. Apply a thin layer of special grease P/N 12345579 to the frame rail mounting surface and the mounting flange of the sensor. Do not apply the grease to the mounting bolts or holes. 2. Forward discriminating sensor, with arrow pointing toward front of vehicle. 3. External tooth lock washers, P/N 11501869 (8 mm) and 121753 (6 mm) to mounting bolts. 4. Sensor mounting bolts. Ensure that washers are between bolt head and senor mounting flange, not between mounting flange and frame rail. Tighten Front (13 mm head) bolt to 25 N.m (19 lb. ft.) - Rear (10 mm head) bolt to 14 N.m (125 lb. in.) 5. Sensor electrical connection, then clip completed connection into retainer. 6. ECM and support; refer to DRIVEABILITY AND EMISSIONS (SECTION 6E3). 7. Battery; refer to BATTERY (SECTION 6D1). 8. Yellow two-way SIR connector at base of steering column and Connector Position Assurance (CPA). 9. Left sound insulator; refer to INSTRUMENT PANEL, GAGES & CONSOLE (SECTION 8C). 10. Perform "SIR Diagnostic System Check" as outlines in SIR SYSTEM DIAGNOSIS (SECTION 9JA). RIGHT SENSOR CAUTION The following procedures must be followed in the order listed to temporarily disable the Supplemental Inflatable Restraint (SIR) system and prevent false diagnostic codes from setting. Failure to follow this procedure could result in possible air bag deployment, personal injury, or unneeded SIR system repairs. Remove or Disconnect 1. Turn ignition switch "OFF." 2. Left sound insulator; refer to INSTRUMENT PANEL, GAGES & CONSOLE (SECTION 8C). 3. Connector Position Assurance (CPA) and yellow two-way SIR connector at base of steering column. 4. Six front right-side rocker panel retaining screws. 5. Right-side front fender "grill panel" retaining bolts, remove fender. 6. Peel back rear portion of wheelhouse-to-hood seal. 7. Right-side lower wheelhouse retaining bolts; remove lower wheelhouse. 8. Two front windshield washer reservoir retaining bolts. 9. Loosen remaining washer reservoir bolt; rotate reservoir to access sensor. 10. Sensor mounting bolts. 11. Sensor electrical connection from retainer; disconnect connection. 12. Sensor from vehicle. IMPORTANT Clean Sensor mounting bracket surface, frame rail mounting surface, and mounting bolts and holes to remove any paint or corrosion that might interfere with a good electrical ground. CAUTION: Proper operation of the sensors and Supplemental Inflatable Restraint (SIR) system requires that repairs to the vehicle structure return it to its original production configuration. Deployment requires, at a minimum, replacement of the DERM, both forward discriminating sensors, the SIR coil Assembly, and the Inflator Module. Any visible damage to the sensors, DERM, and/or the DERM mounting brackets requires replacement, and the steering wheel must be dimensionally inspected, whether deployment occurred or not. Proper operation of the forward discriminating sensor requires the sensor be rigidly attached to the vehicle structure and that the arrow on the sensor be pointing toward the front of the vehicle. Install or Connect 1. Apply a thin layer of special grease P/N 12345579 to the frame rail mounting surface and the mounting flange of the sensor. Do not apply the grease to the mounting bolts or holes. 2. Forward discriminating sensor, with arrow pointing toward front of vehicle. 3. External tooth lock washers, P/N 11501869 (8 mm) and 121753 (6 mm) to mounting bolts. 4. Sensor mounting bolts. Ensure that washers are between bolt head and sensor mounting flange, not between mounting flange and frame rail. Tighten Front (13 mm head) bolt to 25 N.m (19 lb. ft.) - Rear (10 mm head) bolt to 14 N.m (125 lb. ft.) 5. Sensor electrical connection, then clip completed connection into retainer. 6. Position windshield washer reservoir; install retaining bolts. Tighten Reservoir mounting screws to 10 N.m (89 lb. in.) 7. Lower wheelhouse and retaining bolts. Tighten Wheelhouse to "U"-nut bolts to 6 N.m (54 lb. in.). - Wheelhouse to frame member bolts to 9 N.m (80 lb. in.). 8. Reposition wheelhouse -to-hood seal. 9. Right-side front fender ("grill panel"); install retaining bolts. 10. Six front right-side rocker panel retaining screws. 11. Yellow two-way SIR connector at base of steering column and Connector Position Assurance (CPA). 12. Left sound insulator; refer to INSTRUMENT PANEL, GAGES & CONSOLE (SECTION 8C). 13. Perform "SIR Diagnostic System Check" as outlined in SIR SYSTEM DIAGNOSIS (SECTION 9JA). -END- |
12-21-2012 | #5 |
Re: INF Reset
This I believe can be used to check the sensors:
12-21-2012 | #6 |
Re: INF Reset
If all of that fails and you'd just like to put out the SIR lamp and the "SeatBelt" warning in the cluster you can substitute a 2 Ohm 2% resistor at the connector either at the top of the column(un-plug bag) or at the column base which is much more difficult to get to. That should put out both lights I believe.
Early air-bags punch pretty hard!!! |
12-21-2012 | #7 |
Re: INF Reset
There are a few more INFL REST pages in "Technet" part of the ZR-1NetRegistry webpage at:
http://www.zr1netregistry.com/Inform...-REST-fix.aspx Note at the bottom of that page you'll see link-backs to several other forum threads on same as well as links to other Technet articles on INFL REST.
Scott Vett owner since 1979._It's about the car and the people Last edited by scottfab; 04-04-2014 at 12:02 AM. |
12-22-2012 | #8 |
Re: INF Reset
Sorry for being a novice to electronics.
I hooked the Tech 1 and it actually works, not bad for $375 last year. I got through the Vin selection and it asked what test to run. I was using a GM Powertrain cartridge P/N 02002404 and got totally lost. In the Service Bulletin it states use Tech 1 P/N 94-00101-A or 1991 body system cartridge TK04040A to reset. If I buy a mass storage cartridge will I have everything I need. Have do you navigate to get to the SIR testing? When using the K ground method the INL RESET light flashed not the ENGINE Light is this correct?
Erv Myers 1990 ZR1 #1964 Last edited by Socalerv; 12-22-2012 at 01:11 PM. |
12-22-2012 | #9 |
Re: INF Reset
If you find a mass storage cartridge please pass along where you found it as my Tech I came without it and I cannot even get the bloody thing to turn on without it?
Wayne |
12-24-2012 | #10 |
Re: INF Reset
not to be a wise guy, but besides getting to the right sensor which is under the washer bottle the hardest part for me was clearing the damn code.....I don't have a Tech1 or a 1A but a MT2500 and no body cartridge. Anyway, I went to the hardware store and bought a door bell push button assemblt, wired it up with phone wire and plugged it into the ALDL and grounded the other lead on the hinge pillar. I used my phone's stop watch to get the timing down and cleared it on the second attempt. The key is the timing if you don't have the proper software. If you miss on the timing, the code will not clear. The only thing to remember is that to ground the system you have to press the door bell. Other than that quirk, it is easy and cheap. I tried doing the One One-thousand thing but never got it cleared....I was ready to just pull the bulbs until the door bell and a stop watch idea hit me ....yea I know, a BFO moment! LOL
