05-04-2012 | #1 |
Seat belt retractor FYI:
Got into the Z this morning, went to put on my seat belt, and the lap belt portion wouldn't pull out of the retractor. Tried over and over again, pushed the cinch button repeatedly to see if something was jammed, no dice.
Got home this evening, and removed the retractor unit, and opened it up. There was a good few tablespoons' worth of lint, grit, etc, all around the inertia lock pendulum and associated levers. Blew it out with some pressurized air, and it works as good as new! For reference, I also spoke with Carlos at Seatbelt Solutions. They quoted me $350 to re-web both sides (LH and RH), and another $50 to repair the stuck retractor. While obviously I don't need the repair anymore, it's nice to know that there's an option for having the webbing redone (which is probably not a bad idea at 20+ years of age).
05-04-2012 | #2 |
Re: Seat belt retractor FYI:
These new OEM sets can be found from time 2 time for alot less than $400+.
05-04-2012 | #3 | |
My post wasn't to plug this company whose quality I have no knowledge of. The point was to explain that a stuck retractor might just be stuck due to 20 years of crud inside the housing.
2004 Z06/Z16 LeMans Commemorative Edition 1991 ZR-1 #302 White/Gray (sold) 1991 ZR-1 #1147 Red/Saddle (sold) Last edited by VetteMed; 05-04-2012 at 11:05 PM. |
05-05-2012 | #4 |
Mine made a bad squeal when the belt extended and retracted and sounded cheap every t me may fat azz bounced out of the seat on bumps etc. A little air and silicone lube in the guts fixed it right up.
05-05-2012 | #5 |
When I pulled mine out I found coins, lint, paper, food etc. lol
05-06-2012 | #6 |
OK, apologies in advance for the semi-hijack....
I just hate when you open up the secondaries and the belt cinches from the G force (particularly when its just after lunch or dinner...). Is this normal?
[SIGPIC][/SIGPIC] __________________ 1990 Corvette ZR-1 #2824 4.10's, Custom PROM, Flowmaster, Top End Port NCRS BC Chapter |
05-06-2012 | #7 | |
Might be worthwhile to open it up and clean it out
05-06-2012 | #8 | |
I'd assumed it was a "feature". This is going to the top of my "To Do" list.
