Anyone have a stock $AF bin? I have an $AFA file.
![]() Join Date: Feb 2011
You mean the XDF definitions? I have them both on my work laptop right here.
It doesn't work with mine- says CYL volume is 5.0 liters-
what is the history with that definition...what cars came with it? |
Watcha doing Dom? BTW did Bill give you a call?
#6 | |
There are 2 versions of each def. file ie $8E/$8EA. The "A" versions were service mods. GM added a few lines of code to each def file. Cyl. Vol is one of the parameters that comes AFTER the point in the code where GM inserted the changes and that's why you get a goofy number. One way to check you're using the right version. You don't want to modify and save the bin using the wrong MASK ID. :-( GC, Somebody has an $AF chip and we wanted to modify one of the parameters not currently shown in the $AF files that are out there. All the broadcast codes I have are for $AFA mask and I'd like a $AF bin to do a compare. Bill has not contacted me. Give him my cell if he'd like to chat. Last edited by XfireZ51; 04-06-2012 at 08:51 AM. |
![]() Join Date: Jan 2009
Dom,
Are you dealing with an ARZR BCC bin file? I believe that the AXFK and BFXB are both 'AFA' masks, correct? Jep |
#9 |
Dom,
What is the value of the first two bytes of the binary file? That will tell us what the BCC is. Jep |
