Old 03-16-2006   #1
BBBAD94ZR1
BBBAD94ZR1's Avatar
Default COOLANT LEAK
Anyone ever encounter a leak by the collant resivor on the right side? I seem to have coolant around that area after the car cools down. What is the small black Pvc hose by the tank? What purpose does it serve? It comes off the plenium. Im going to take it apart tonight.
Thanks
RAY
[FONT=Century Gothic][SIZE=5][COLOR=black][I]:dancing[/I][/COLOR][/SIZE][/FONT]
BBBAD94ZR1 is offline   Reply With Quote
Old 03-16-2006   #2
BBBAD94ZR1
BBBAD94ZR1's Avatar
Default Re: COOLANT LEAK
Found out why, previous owner had the tank over filled.
Ray
Old 03-17-2006   #3
Small plastic hose = vacuum supply hose for the secondary port system from the vacuum pump above the coolant overflow tank.
