10-19-2011 | #1 |
Parting out 91 LT5
I have a 91 LT5 I am parting out.
This engine is apart I have most parts still but hit me up with what you need and We can see if I have it and see if we can agree on a price. sold one camshaft need to verify what I have. I believe it was the LH exhaust. Sold Left RH head again let me know what you need and we can talk. jp quick inventory today Used parts from a 30K motor that I intended on building but needed money and parted some of it so now its time to finish the job. 2 bolt block with lader $1000 oil pan $300 oil filter housing $300 LH cylinder head $900 drivers side three camshafts $300 each air horn $100 throttle body Sold power steering pump $350 RH chain tensioner with housing compressed $400 LH chain tensioner with housing compressed $400 front engine cover $150 A/C compresor for 91-up $250 brand new secondary vacum pump the one from the truck $200 Coolant tubes $250 Pistons with conecting rods $100 each I have a a bunch cylinder liners $100 each I have a bunch not from the above block Spark plug wires MFG by Taylor used $40 spark plug wires LT5 sold rear crankshaft seal housing $150 fuel pump assembly used $200 AIR parts group $300 Intake accordian Sold crankshaft is iffy I remember it havind some surface corrosion on it so not sure if it would be worth using to anyone. NEW PARTS White Racing products Crankshaft bearing set $650 Camshaft timing chain wear strips or guide facing I have Two of the cam cover guide facings and three of the ones for the main chains $350 for all of them
JOHNNY P Currently own 90 ZR-1 #845 DRM 500 engine package 90 #226 Parts car Hit me up if you need anything. Last edited by phrogs; 12-07-2011 at 06:27 PM. |
10-19-2011 | #2 |
Re: Parting out 91 LT5
P&A
Ignition module Ignition module interface board primary timing chain sprocket
[SIZE=3][B][COLOR=Red]Worlds largest ZR-1 LT5 Parts Store[/COLOR][/B][/SIZE] [URL="http://whiteracingproducts.com/"]http://whiteracingproducts.com[/URL] New & Used Parts, as well as free Locator services. [EMAIL="sales@whiteracingproducts.com"]sales@whiteracingproducts.com[/EMAIL] (813) 264-6368 |
10-19-2011 | #3 |
ECM?
10-20-2011 | #4 |
Plenium and coolant pipes
10-20-2011 | #5 |
Goldy, I have the coolant pipes off my '90 if you need a set.
10-20-2011 | #6 |
Plenum and IH...if Goldcyon passes.
thanks sam
Sam 1991 ZR-1 :salute: |
10-20-2011 | #7 | |
I have one ignition module see them going for a lot of bucks.. one on ebay went for over $800 in the last two weeks. interface board sold to you I think months ago. Need to check on the timing chain sproket it might be in the block I need to pull the front cover off Ill let you know asap if I have it. I do have an interface board but depends on how much you would give me for it since its from my spare motor.
10-20-2011 | #8 |
plenum sold!
See above for coolant tubes.
10-20-2011 | #9 |
Sorry both are sold from this one.
10-20-2011 | #10 |
