Old 10-15-2011   #1
Corbusa
Default I finally drove my car today
I had the car almost 2 weeks and finally got to take her out. It was really nice just to get away and take a drive . ( I've been working day and nite lately and I sure needed a break).
There are a few things I need to know about the car and I dont have the owners manual. Maybe you guys can tell me where to by one or if some one can copy it.. I like to know what all the buttons are for the seats and on the dash ..Its simple but there still might be some info I need to know.
I posted a thread about the engine making a noise last week , It seems to be a low RPM under a load B/T Idle and 2k rpm . You really cant hear it at idle( just a little) But when its in gear and just idling I hear it. It actually sounds like the old army pick up trucks with a diesel.The kind of rattle they make,But this one isn't bad. It drives and handles Great , No miss under a load no sloppy performance. So I'll drive her until I figure it out . It only has 34K miles and had Amsoil in it the whole time so I seriously doubt it is a major issue.. But if any ZR1 guys here pass thru TN you're welcome to stop by and listen. I have a spare room too. If I'm not here he doors open .
Old 10-15-2011   #2
mike100
Default Re: I finally drove my car today
The ZF transmission is notoriously noisy, especially if it has been converted to a single-mass flywheel or the original dual mass unit has a slight bit of wear and tear on the internal spring setup causing a little knock at low speeds.
The dual mass rattle can be exasperated by anything that causes a less than perfect idle- like bad injectors or weak ignition etc.
The ZF might sound like it is full of gravel at certain resonances and some boxes have a pitched whine...either way, this is fairly normal and so long as the proper lube is in the transmission, nothing to worry about.
Mine used to knock about before i put in new injectors and spark plugs (my inj. were bad), but even now it will rattle a bit when i turn the car off and it speeds down to 0 rpm.
Old 10-22-2011   #3
jrd1990zr1
jrd1990zr1's Avatar
What year owners manual you looking for? Your talking about the one that came in the glovebox correct??
1968 convertible Lemans Blue,
1986 coupe Medium Blue NCRS Top Flight (sold),
1990 ZR1 #2529 Red NCRS Regional and National Top Flight (sold),
1990 ZR1 #2124 Charcoal Metallic NCRS Top Flight 2010 & 2018,
2003 Anniversary Red Convertible (sold)
Old 10-22-2011   #4
Corbusa
Thanks for the reply gentlemen, My car has new ( MSD? ) coils and the newer injectors.It runs perfect .... I just got myy oil in yesterday and on my way to napa to get a filter , then build some ofthe wooden ramps mentioned on a thread lately.. Thanks for the reassurance Mike..
JR I'll be looking for a 1990 ( yes the one in the glovebox ). Its not a huge priority right now But when a deal comes along I'll get one.. I have a few things I'd like to get for the car , Spare delete brace, change the trans fluid, a few little odds and ends, But all will have to wait until next month .. This month really cost me, I have my first payment due, 3 tags , 2 insurances, and the vette taxes.BUT I"M HAPPY! I got my car and just got a call this morning to do more work on a remodel I've been working on. yeehhaa.
FYI I have a 4 car carport and all the stalls have concrete except one , But soon I'm gong to pour a slab and build a concrete car ramp or a pit to drive cars on ...I used to be a pretty good mechanic and getting this vette woke up the sleeping giant Thanks
Old 10-22-2011   #5
jrd1990zr1
jrd1990zr1's Avatar
FWIW you may want to consider a 4 post storage lift instead of a pit. They work well for detailing the rockers, change fluids, etc. If you have the headroom you might even have room for a second Z.
Old 10-23-2011   #6
Corbusa
Not a bad Idea . I might be able to fit one in.. and I know someone who I might get a good deal from. thanks for thr reply... Nice rides too
