Old 09-13-2011   #1
Don in VT
Default WTB 90 ZR1 cruise control clutch pedal disconnect switch
Hi,
I want to buy a workable clutch pedal switch that disconnects the cruise control. The switch must include the two fasteners/nuts that connect the switch to the mounting bracket. This is for a 1990 ZR1.
Thanks,
Don
Don in VT is offline   Reply With Quote
Old 09-13-2011   #2
Default Re: WTB 90 ZR1 cruise control clutch pedal disconnect switch
Don try Bill Boudreau the ZF.DOC
http://www.zfdoc.com
Old 09-13-2011   #3
WVZR-1
Originally Posted by Don in VT View Post
Hi,
Thanks,
Don
I'm quite sure the switch isn't retained with two jamb nuts, it could likely be done in that fashion but I don't know why. The jamb nuts are an everyday hardware store find.
It's retained by a single barrel style retainer that fits into the bracket and the switch is easily adjusted with a push to the pedal. I might be able to do an NOS switch. MIGHT!
If it's only important that it's functional there's several switches that will work. Do them frequently.
If you're interested in a retainer and a switch fine.
Old 09-14-2011   #4
Don in VT
Hi WVZR1,
Thanks for the reply. If you can locate a workable switch with the barrel type fastener please let me know. My switch is "flakey" as it sometimes works and sometimes doesn't. If I can get a new switch with the appropriate fastener I will be good to go.
Thanks again,
Don
