07-10-2011 | #1 |
Ported Intake
I have a fully ported Plenum I/H set ready to go on an exchange basis.
These are 90-92...93-95 are 34mm stock 35mm ball passes completely through on primaries....... IHs are blasted to aluminum and ready for paint or PC Can blast plenum also $700 plus your INJ Housings and Plenum Shipping not included 35mm fooseball I welcome questions, but please keep comments not related to sale out
LGAFF 90 #966-150K miles-sold 92 #234-sold 1987 Callaway TT #17 1991 ZR-1 #1359 Last edited by LGAFF; 09-28-2011 at 12:23 AM. |
07-14-2011 | #2 |
Re: Ported Intake
I expect that's probably about the cheapest 30ish HP one can add.
I like this deal - but am putting off for my winter project, will definitely want to discuss options in the fall. GLWS
[SIGPIC][/SIGPIC] __________________ 1990 Corvette ZR-1 #2824 4.10's, Custom PROM, Flowmaster, Top End Port NCRS BC Chapter |
09-28-2011 | #3 |
Re: Ported Intake
Bump
09-28-2011 | #4 |
Re: Ported Intake
I keep thinking of these but am having a kind of classical year - you know, "baroque". OTOH I did skip buying tires this season so as to be able to address some things on the car.
Can you tell me what the change is from the porting to the head on a 91? By race class rules I can only go 1 inch into the head, and I worry that an aggressively ported IH/Plenum might make too big a step to take up in an inch. Not to mention how would you go about making the shape to take up the step - a conical hone type of thing?? Has anyone ever bolted the likes of these on a virgin head? What kind of gains can be expected with the stock heads? I would love to make these work; what the heck the rules allow it.... They'd even save a few pounds up high! Thanks, - Jeff
[I]91 ZR-1 #1840, autocrossing in SCCA BSP. FIC S/S's DRM chip/Watson/Borla/lid/LW batt&headlights, springs, shocks, pads & lines, quick rack & Turn One, camber brace, 32/22mm sways, A/C halfway deleted 17x11 & 12 CCW's, 315 & 335 Hoosier A6s [/I] |
09-28-2011 | #5 |
Re: Ported Intake
The secondaries start out as 36mm on the cylinder head side. You can do port match and keep it within an inch. It all helps. I had 36mm porting on top end with a port match at the head. Still developed ~399rwhp.
09-28-2011 | #6 |
Re: Ported Intake
Possible sale pending....but like Lays....we'll make more....
10-01-2011 | #7 |
Re: Ported Intake
Going to use a local PC guy here, will do AH, Plen, Coolant tubes, IHs for about $150-225.
German Silver Flat Silver Silver w/metal flake Polished Aluminum
10-04-2011 | #8 |
Re: Ported Intake
Hi:
Do you also do the same for 93-95 (the pre-ported parts in exchange for stock) ?
Thanks ... Paul (Paul in VA) WAZOO Member |
10-04-2011 | #9 |
Re: Ported Intake
Do you offer the same type exchange for 93-95?
10-05-2011 | #10 |
Re: Ported Intake
If I had a set of 93-95 IHs and plenum I would do the exchange, but I do not. And buying a set is pricey....I would be willing to do a set over the winter, but I work and do not want to make a promise I can't keep in terms of time line.
