Old 07-07-2011   #1
Paul in VA
Default 1991 ZR-1 looking for a Spare Tire Delete...
Hi All: Any of these out there ?
Thanks ... Paul
(Paul in VA)
Paul in VA is offline   Reply With Quote
Old 07-07-2011   #2
Kevin
Kevin's Avatar
Default Re: 1991 ZR-1 looking for a Spare Tire Delete...
can't say i've ever heard of this. couldn't you just remove the tire/carrier?
Old 07-07-2011   #3
Are looking for the aluminium brace ?
Frank Urbo.
NCM Lifetime member # 982
Registry Founding # 237
Old 07-07-2011   #4
Paul in VA
Yes... sort of. I think there is a aluminum I-beam that replaces the spare tire. It spans the gap left when the spare is not in place. The concept with the I-beam is to provide the resistance (in a crash) that the spare tire provides normally. My understanding is that the spare tire is an essential component in rear end crash protection. It's strength/size/mass/whatever is critical to surviving a rear end type crash.
Thanks ... Paul
(Paul in VA)
Old 07-07-2011   #5
Kevin
Kevin's Avatar
i've heard the theory that the spare tire is part of the rear impact system and I'm not sure that I buy. I don't see the ntsb allowing something that can be easily removed to be part of the crash support system.
for example, if you blow a rear tire, you won't have anything there to absorb the impact of the crash if the theory is to hold true
Old 07-07-2011   #6
I have the spare tire delete that you are talking about. Also have a spare one that's new.....not that new would matter.
Frank Urbo.
Old 07-07-2011   #7
PMed.
Frank Urbo.
Old 07-07-2011   #8
Paul in VA
PMed back.
Thanks ... Paul
(Paul in VA)
Old 07-07-2011   #9
Kevin
Kevin's Avatar
well i was wrong
Old 06-14-2013   #10
Helium3
I could use a spare tire delete as well...I know this thread is 2+ years old...
Helium3 is offline   Reply With Quote
