Old 05-31-2011   #1
Default WTB,clutch interlock switch.
The part number for this is 10045822 and the AC Delco part number is D2213A.Im diggin,Ill find one but might need some help.Thanks.
Old 05-31-2011   #2
Default Re: WTB,clutch interlock switch.
Any C4 will do or jumper it like I did.
Old 06-09-2011   #3
I find it hard to believe this switch is nowhere to be found.Does anybody have a used one for sale,only need the plug so it doesn't need to work.
Old 06-09-2011   #4
mike100
I have been to Shawn's place in Vista Ca (CorvetteNutz), and I'm sure he has a harness and or switch to scavenge this part from. Boxes and boxes of parted out stuff plus several cars at any given moment. I know there is some LT5 stuff in possession as well.
Here's his running post in the parts section in CF C4 section
http://forums.*************.com/c4-p...-c5s-look.html
as always, manually type in CF (spelled out) to fix the link. his website is not running.
Old 06-10-2011   #5
I talked to Shawn,he wants $55 for the switch.Cant see paying for a used switch when all I want is the plug but thanks for the info.
Old 06-10-2011   #6
Blue Flame Restorations
I tried to find one but couldn't.
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 06-10-2011   #7
Thanks for your time Brett.
Old 06-10-2011   #8
mike100
I've had better luck going in person with a $20 spot...There was also a guy in Florida who I bought a few things from off of ebay too- a recycler parting out cars, but still, maybe you can find the switch in another GM car in the local boneyard.
Cadillacs seem to have the same electrical stuff and you know those things are stacked up at the junkyard like cordwood.
Old 06-10-2011   #9
Kevin
Kevin's Avatar
i don't know if this will help you or not but the reason that the switch fails is that the part is under designed for our cars
Old 08-01-2011   #10
mike100
Is this the switch?
http://carsnewparts.com/products/clu...7-p178463.html
