Old 05-10-2011   #1
mike100
Default FX3 custom valving
The Bilstein shop is local here in town, but before I call I wanted to ask if anybody has done anything special with their FX3 shocks.
After putting a few miles on my '91, I have some thoughts on the stock settings.
1) Basically the Tour setting is too soft-even for the speed limit.
2) The stiffness (compression) is ok and can be adjusted with the knob. This could be further altered with a new controller (like the Lingenfelter one).
3) The rebound is waaaay too soft and allows a lot of old school tuna-boat bounce when you get going a little faster over dips etc. I either have worn out shocks, or, what I suspect more, Bilstein always valves their shocks a bit cushy-which has been my experience.
Somebody tell me about anything they have done to sport up the system more. I will call the rebuild shop, but I think my opinion is going to be to maybe stiffen the compression up 5% and maybe 20% or more on rebound if possible.
Old 05-10-2011   #2
Daniel_Mc
Daniel_Mc's Avatar
Default Re: FX3 custom valving
I am running the moracco valving with a custom controller on the FX3's for my 89 track car and it is much better than the stock FX3 set up it is firm in tour and just gets stiffer. I still feel it could be a little more stout.
Hope this helps.
Daniel
Daniel_Mc is offline   Reply With Quote
Old 05-10-2011   #3
mike100
Hope this helps.
Daniel
Ok...I do want it to be firmer (with or without the controller), but not too stiff for the street. I've heard of the valving, but I guess i can ask about it when I call them. I really mostly want them to physically dial in more rebound damping- hopefully they can do it on these shocks. I know they can on their standard ones.
Is your stiffness more from the controller setting or the valving?
Old 05-10-2011   #4
Mike,
I'm with you. I have the DRM coilovers on mine but would like a firmer ride particularly on the rebound. Keep us posted on what you hear from Bilstein.
Old 05-10-2011   #5
from a CF thread in 2007:
- Bilstein also just gave me more info on this - they do still sell a controller and chip that forces a 75% front lock and a 100% rear lock "all the time" as an option. It makes the car very unfriendly for the street and I think that's why they originally said to go with the stock controls.
Old 05-10-2011   #6
Daniel_Mc
Daniel_Mc's Avatar
Mike,
I would call Randy at DRM he knows the stuff and especially these cars. Sounds like what you are looking for is shocks only I don't think the controller is what you are looking for. The turnaround is quick if you are going to have them rebuilt, something like 3 weeks, and if you are even thinking of going coil-overs go ahead and have the snap rings installed for the sleeves.
Daniel
Old 05-10-2011   #7
lbszr
lbszr's Avatar
Here's a link to some set up options for the fx3 and a really nice Z.
http://www.cardomain.com/ride/418999...orvette/page-8
I didn't realize gm programmed the controller for 150mph before the shocks are in full firm mode, I mean, come on, what were they thinking
Old 05-11-2011   #8
mike100
Bilstein is about a 10-15 minute drive from where I work, so I will try to make time tomorrow to ask them if they can do what I want with FX3 shocks. If they aren't too busy, I would plan to remove the shocks and maybe get it turned around in a week.
I recall back in the 90's I was able to drop off shocks in the morning and get them on the way home from work. The one thing I hope for is to talk to somebody who actually knows about the things (I might have to drive over there). I do not think the shocks are actually in need of a rebuild- they are in much better condition than my fx3 on my 95, but I'm sure the charge would be about the same just to take them apart.
Old 05-11-2011   #9
I don't see a link
Old 05-11-2011   #10
lbszr
lbszr's Avatar
I don't see a link
Sorry about that. Must be the beer.
