09-09-2010 | #1 |
After driving car for 7-10 minuts...
After Mechanic changed the coils,spark plugs, i drove the car for testing, every time i drive the car, the engine stall and die after 4-5 miles, then when i crank the engine,the engine start little bit and move for couple of feet then die, and i have to wait for half hour to start over and drive the car for another 5 miles,then stall and die!!
what the hell is problem anyway? P.S.This basrad Lie to me begining that he could not drive and test the car, then afer facing him him how he could know the clutch is bad, he told me that he drove the car for 15 miles!! hmm, he F**k the clutch, but i want already change the flywheel and clutch! after 3 months leaving the car with him, all i need now the car run normaly without issue. Last edited by HADI-ZR1; 09-09-2010 at 03:26 PM. |
09-09-2010 | #2 |
Re: After driving car for 7-10 minuts...
Just drink some Stoli's and forget about it.
09-09-2010 | #3 |
Hadi,
Sounds like you have a bad primary fuel pump. When the engine is cold, start the engine and just let it run. if it warms up & dies at 176F (I think that's about right), then it is the primary fuel pump. There are a couple of checks.... Engine cold; Install fuel pressure gauge on the fuel rail, Pull the secondary fuel pump fuse Key on low or no fuel pressure = bad primary fuel pump key off replace primary fuel pump
Jerry Downey JERRYS LT5 GASKETS & PARTS http://www.jerrysgaskets.com 1994 ZR-1, Black/Black, Lingenfelter Aerobody, 416cu in, 3.91 gears, coil-over susp, Brembo brakes, etc. 2016 Black-Red, 3LT-Z51 Auto 8-speed. Last edited by A26B; 09-09-2010 at 04:06 PM. Reason: corrected temp |
09-09-2010 | #4 |
Jerry thanks for info. i will try this tomorrow and let you know.
P.S. He told me that he removed some water from tank, I just put new injectors ,i hope its not bad now?! the car been parking outside in Snow for long time!. I replaced the 2 fuel pumps with AC delco last year. |
09-09-2010 | #5 |
09-09-2010 | #6 |
I believe they're in the panel under the glove box.
09-09-2010 | #7 | |
When started cold, Both pumps work at the same time until engine temperature reaches 176F. After that, the secondary pump shuts off.
09-09-2010 | #8 | |
P.
09-10-2010 | #9 |
Hadi there are 2 fuses the one Feul Pump fuse is on the side panel of the passanger door it will say FP1.
The other is under the dash kick panel passanger side you need to remove the panel it will say FP2. If you remove the FP2 fuse and your Z does not start then you will have to replace primary pump. Like Paul said just because it's new does not mean sh!t Pete
09-10-2010 | #10 |
Ahhhh, the difference is between early & late model ZR-1's. In my 94, bot fuses are in the panel on the side of the pass door. I'll try to store that for the future. Thanks for the correction Pete.
