12-09-2005 | #1 |
Looking for a 1991 ZR-1 Full Power Bypass Harness
Looking for a 1991 ZR-1 Full Power Bypass Harness. Not really interesting in swapping chips.
The harness is no longer offered in all the catalogs I have but maybe someone has one they never installed. |
12-21-2005 | #2 |
Re: Looking for a 1991 ZR-1 Full Power Bypass Harness
Doesn't look like I have any choice .After checking out my chip and finding out its stock, I will probably now just change it out this spring and have it programmed so the power key is turned on.
ZR-1 Mack ... 91 ZR1 Black/Black #487 NY |
12-22-2005 | #3 |
mack
im confused as what you are asking a full power bypass harness???if you order the switch for the 91/95 this comes as an assembly,unless you mean the harness to the ecm????and also i just checked on the rear bumepr cover gm has not yet discontinued this they have no stock but i can get one using a vin an assigning a spac case.. peter |
12-28-2005 | #4 |
Peter,
In Mid America Motor Work there is a Full Power Bypass harness for 92-95 ZR-1s P/N 609-151 in the C4 catalog In earlier catalogs there was also one offered for 90-91s. The harness for the 90/91s is now discounted by Mid America, Corvette America and Ecklers. Since I can't find one I'm just gonna go to a new chip where the full power key will always be on .
12-28-2005 | #5 |
[quote=yellowz]mack
gm has not yet discontinued this they have no stock but i can get one using a vin an assigning a spac case.. Peter ... Thanks for the info. Limey from Whites Racing Products was on another forum and mentioned this. I didn't try to order one... so that's good news. I hope I never need to buy one!
12-30-2005 | #6 | |
12-30-2005 | #7 | |
I'll let you know what happens. Ron
